Question about Whirlpool Washing Machines
My washing machine shakes so much when spinning that it comes out of it's slot from under the counter. I think the weight in the machine has fallen as there is cement dust on under the machine
  • 14 Answers
Sometimes the concrete weights come loose, it will need to be dismantled ( back, top, front, off) to see where. could need new fixing bolts or screws. when weights have been refixed ,make sure the machine stands firmly on the floor on all four feet and doesn'twobble at all
Posted on Oct 06, 2008
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Why is my basket leaning to the side on my easing machine
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Sep 06, 2014 | GE Washing Machines
I moved my Kenmore 400 series washer into our new house and now it makes a loud banging noise, and vibrates real bad on the spin cycle. It shakes the dryer beside it it's so bad. If I sit on the washer it...
THERE S A THIN NOT REAL LARGE CONCRETE BLOCK INSTALLED AT THE FACTORY UNDER THE MACHINE. A STRAP MAY HAVE LOOSENED OR BROKE, AND THE BLOCK MAY BE MISSING. ANY SMALL YET HEAVY WEIGHT WILL WORK.
IT APPEARS YOUR BOOTY MAY BE ACTING AS THE COUNTER WEIGHT!...IF NOT,,CHECK THE CONDITION OF THE TRANSMISSION COUNTER WEIGHT (AT BASE OF TUB UNDERNEATH)
Nov 04, 2013 | Washing Machines
Sounds like a jet plane taking off when it spins, I think I got in 2003 Also the top of the agitator wont stay on
Has it always sounded like a jet plane? If it has. Then who installed your new washing machine didn't disengaged the two counter weight inside the washing machine. There two concert block or plastic block inside the washing machine. Each block is attached to one end of counter blanching bar which has some spring attached to them. During manufacturing these weights are tied down for shipment. During installation the ties are removed then the washing machine can be leveled.
Counter weights are used to off set the uneven load in the tub. That way the washing will not start walking in the house. Side load washing machine use a plastic donut the fits around the drum and it fill with fluid for counter weight.
Now the cap of the agitator, it broken. The locking tabs are broke off. needs to replace. I hope you said the top of the agitator and not the agitator is coming out. If it is, you got major problems. stewbison
Aug 20, 2011 | Amana Washing Machines
Estate washer bangs and shakes like crazy in spin cycle after being moved from one house to another.
has it been releveled? if it has then it sounds like there is a problem with the counter weight or suporting springs/bracket the only way to tell is to check inside the machine.
Jul 28, 2011 | Washing Machines
Machine shakes, rattles and "walks"
Possible that the drum is out of alignment, You will need to check the motor mountings, check to see if the suspension of the drum is good. if not remove and reset, check the counter weights and the shock absorbers.
Also check the drive shaft and the agitator assembly. finally the footings to be firm, use a water level to set.
May 16, 2011 | LG Washing Machines
I have a cabrio washer machine and when is spining it make a bad noiice and stop I check level and the lvel it is ok
Check the bottom of the tub for a loose counter weight. it may have come loose or fallen off. Here is a link to a diagram that shows the counter weight. It is number 13 on the diagram.
Nov 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
