Question about T-Mobile Wing™ Smartphone
Tmobile wing screen searching for SD card
My tmobile wing screen is currenlty
red, green, blue and white in bands
with some serial numbers. i can hit the reset
button and the screen clears then says
searching for SD card...? have no clue what
that is or what that means
  • vojeff Oct 13, 2008
    same exact problem
  • nelsonl55 Dec 21, 2008
    how to unlock ur phone if u forgot the password
  • 3 Answers
Ok first you need microsoft sync on your pc second you need to download the wing update from t mobile it will walk you through the process the bars you are seeing means it is in flashing mode this software will fix the problem any questions e mail me at blok420@yahoo.com
Posted on Oct 22, 2008
Schemas cable VGA monit. Philips 107
1)-red
2)--green
3)--blue
4)--ground
5)--ground
6)--red(ground)
7)--green(ground)
8)--blue(ground)
9)--+5v from vga card
10)--stand by
11)--synchronus ground
12)--serial data
13)--Hsync
14)--Vsync
15)--serial clock
Mar 28, 2010 | Fujitsu Siemens 38B1 (White) 15" LCD...
Frozen screen with 4 band colors
Your phone is stuck in bootloader mode, it seems that you may need to reinstall your phone OS on your phone.
Go to the HTC site and download your phone's OS files/installer:
http://www.htc.com/us/SupportDownload.aspx?p_id=67&cat=2&dl_id=68
Follow the installer's instructions after you've downloaded the needed file.
Jul 19, 2009 | HTC Tilt 8900 Smartphone
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Laptop screen has been invaded by green and red/purple germlins
Sorry to tell you but you are describing exactly what an LCD looks like when it has been fractured. Does it work with an external monitor? If so you will need to have it repaired. Call the Fujitsu support number (800)-fuj-itsu and they can tell you where a repair center is in your area. The call is free. Have your serial number handy.
Mar 09, 2009 | Fujitsu AMILO PC Laptops
How to connect a Nintendo Wii Audio Video ED Component Cable ?
Generally the Red, Blue, and Green are video with the remaining red and white are audio left and right respectively.
Dec 28, 2008 | Nintendo Wii Console
My tmobile wing keeps freezing up when I try and text
It took me a long *** time to fix my wing, but this is the only way i found. shout out to my homie muhammed for showing me:
hold both left and right toggle button simultaneously, and use stick to press the reset button. continue to hold buttons....
it will reformat. press send to wipe the phone.
then, use active sync to completely wipe the micro sd memory card once wipe is complete
this will delete the static charge virus
lastly, go to tmobile website and download the rom software upgrade.
reconnect the wing to your pc
charge the phone past 50%
click on the new software upgrade icon and follow instructions.
the screen will show 3 lines, green red and blue with the new upgrade version numbers.
once complete, you have completely upgraded the tmobile wing to the fullest extent
if this does not work, then sadly enough.... your problem is from dropping your phone too many times and causing the components to become loose connections. aka the sliding keyboard.
i also noticed that the only thing stopping the keyboard from stopping is a tiny square piece of plastic. but then again, this phone was crafted in china. chinese plastic isn't the most sturdy composite material.
Dec 01, 2008 | T-Mobile Wing™ Smartphone
My tmobile wing won't turn on
If you have an SD card in your phone take it out and try turning it on. You can take it out when you see it going back to the white t-mobile screen. Once the device is on and to the home screen you can insert the card again.
Oct 28, 2008 | T-Mobile Wing™ Smartphone
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
T-Mobile Wing™ Smartphone Logo
276 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
