Question about Canon PIXMA MP210 Photo All-In-One Printer
Ink catridge installation
Just purchased this and the installation of catridges "instructions" make no sense in relation tot he product - help please!!
  • 3 more comments
  • Anonymous Oct 11, 2008
    Maybe I'm stupid, which I know I'm not. But installing the cartridge is very painful. I don't know maybe I should ask a caveman. They seem to have all the answers and know everything.
  • kielbasaman Nov 10, 2008
    The solution given really didn't tell me anything specific. Installing the Canon Mp210 ink cartridge is aggravating. What is the answer to this problem?
  • Anonymous Nov 18, 2008
    I can't install the cartridges into my new printer. How hard should this be . Canon mp210
  • Anonymous Nov 24, 2008
    i cant install ink cartridges
  • kellywiersma Dec 09, 2008
    this printer is the devil. installing the ink is a total nightmare.
I had the exact same problem, the printer needs to be PLUGGED IN AND TURNED ON. Its only when you turn the printer on that the cartridge holders move into place.
Posted on Nov 24, 2008
Ok. So to install this ink, DON'T tilt the cartridge like the picture shows. You just have to slide the ink in.
Posted on Dec 09, 2008
  • 3 Answers
Just insert the cartridges the printer is smart enough to work it out
insert them and turn it on. it should automatically do an alignment
if it persists reply to this
Steve
complete inkjet solutions
Posted on Oct 14, 2008
Getting "Catridge error: Refer to
if the cartridge is not sensing poperly this error may occur.clean the cartride contact and try it.
the following link may useful to you.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01571812&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3441011
Aug 08, 2011 | HP J3680 Officejet All In One Printer
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
I have purchased hp F 4288 ,the supplier states that the original ink is only for the demo and fresh catridge shall have to be purchaed.The demo catridge quantity ink was not declared at the time of the...
Unfortunately, this is comon practice among printer companies (no matter what manufacturer) Even if purchased New in box. Did you ask how long the ink cartridges would last when you purchased it?
Jul 11, 2009 | HP DeskJet F380 All-In-One Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
What can I do when EPSON does not supply CX4300 Catridges
I bought Epson cx 4300 in Dubai. i could not find any alternative ink for use in india how can i find it in mumbai maharastra india
Mar 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Catridge led blinking
Good day. Stop panick .. check for the cables installation, then try to get the ink tank out then check for burn and dust... Usually this kind from product defect or the Electricity symptons.
Tell me the result..
Regards
Paul
Dec 03, 2008 | HP PSC 1410v All-in-One Printer
Canon PIxma i4200 - INK
see may be there is problem with the catridge bcoz it is not sensing the ink level it is bettre if you have other catridge first you check wit that or you try to remove the ink and claen the cartridge and refill it again. bye
Oct 01, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
69 people viewed this question
old marine
old marine
