Question about Dryers
GE Dryer Model DRSR495 Shutting Down with a full load
I purchased this dryer new in Dec 2006 and it has worked great until recently. Now, when there is a load in the dryer it will not stay on for more than 30 seconds. Sometimes it won't even stay on that long. When there is nothing in the dryer it stays on, spins, and gets hot. I was first thinking it was the switch on the door, so I held in down and it does the same thing. Sometimes when there is a full load it won't stay on at all unless you hold the button down. Also when there is a full load the motor sounds like it is working harder than it should be. Thanks for looking and helping.
  • DavidMitch Oct 05, 2008
    also when the dryer runs empty is doesn't sound any different.
SOURCE: Dryer won't stay hot....
change your coils at the burner.
check the vent for blockage.
Posted on Nov 19, 2008
  • 19396 Answers
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Posted on Dec 15, 2008
SOURCE: Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Posted on Feb 04, 2009
  • 18 Answers
SOURCE: dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
Posted on May 25, 2009
  • 744 Answers
SOURCE: my dryer stays hot
Hello, I'm going to assume this is a Electric dryer since you did not mention :) Ok your problem is with your heating coil. Basically what has happend is the coil has broken and the end that is wired strait to the electric supply is touching the chassis of where the heater is located, You should replace the heating coil and this will solve your problem :) You have a nice day and if there is anything else i can help you with please feel free to comment again. Thanks for using Fixya!! Mike
Posted on Jul 23, 2009
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
Dec 21, 2012 - Uploaded by
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Jul 08, 2008 | Maytag MDE2600 Electric Dryer
GE Spacemaker Electic Dryer Poor Drying
Make sure you have a 30amp two pole breaker. Also, it could be a heater problem.
Nov 24, 2009 | GE Profile DPXH46EAWW Gas Dryer
My GE Profile Harmony Dryer purchased in DEc 2006 has had a rip in the stainless steel drum that has now reached about 2 x 3 inches large and now makes noise and does not dry properly.It appears to be...
The tear is due to a poor argon weld of the dryer drum. Check the owner's manual regarding any warranty details. Call the customer assistance line regarding this issue. Have your model and serial number ready for them to assist you. The tear in the drum is causing the blower on the dryer to pull air thru the tear in the drum instead of thru the rear inlet duct which draws the heat into the dryer. This results in abnormally long dry times due to no heat passing thru the drum.
Aug 19, 2009 | GE Profile Harmony DPGT750EC Electric...
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Jun 01, 2009 | Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Dryer capacity
Yes, a full size dryer as yours is easily capable of drying a full sized load from the washer you mentioned. The wash tubs in the new model washers and dryers still maintain a standard size. For example, the front loader dryer that I purchased to match my front loader washer is completely identical to earlier standard models without all the fancy packaging. I could have saved some money and purchased only the washer, but...the wife needed a matching pair.
Now, you will still have to properly sort items to ensure they dry efficiently. A copy of your dryer owner's manual will describe this to you. I'm not here to give you lessons in how to dry your clothes, but if you do not own a copy of your manual and would like to refer to it, you can obtain a copy at Just look under the "Service and Support" section for "Use and Care Manuals". Just type in your model number and your owner's manual is availble in a downloadable .pdf format.
The point I'm attempting to make here is that although you can place a full load from your washer in the dryer, if you do not properly separate certain items, they will not dry properly. I did not want you to think this was a cause of the appliance.
In addition, make sure the dryer vent ducting is properly cleaned and not clogged anywhere. This can also contribute to longer dry times.
I know you were only asking a simple question. I just wanted to be thorough in case additional question may arise. I hope this information is helpful to you.
Nov 14, 2008 | Dryers
GE dryer shut off prematurely and now won't start
I'm having the same problem with my GE dryer. I think that it may the safety thermostat receaching maximum temperature and shutting the dryer down.
I'm currently researching this problem now.
Dec 05, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
