Question about Samsung HCM5525W 55" Rear Projection Television
Samsung 55" model hcm5525w
Red line bows from top corner to top corner...double vision
    Scholar:
  • 98 Answers
Its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Posted on Oct 13, 2008
How to I fix the picture that is red and greenish blue and appears as double vision on the screen?
Replace Both of your convergence ICs STK392-110 use 150s they are big black ICs will have part number on hem Call Mats 1-800-628-1118
Sep 16, 2009 | Samsung HCM5525W 55" Rear Projection...
Color alignment
Please replace both convergence IC's.
May 27, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung tv #hcm5525w is on but has double vision
The problem sounds like it is the convergence output ic's are bad. I would let a repair man fix it.
Nov 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55inch
This is a convergence problem. It happens to all big screen rear projectors. The convergence output ic's need to be replaced. I would let a repair man do this.
Nov 11, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung hcm5525w rear projection tv
Extensive analysis revealed this unit to be for 120V 60Hz regions. If you use it in a region where the mains supply is 220/240V 50Hz then it won't work. In addition, the PSU will overheat, with possible damage to other modules.
One possible solution is a 120V 60Hz inverter, else Samsung may be able to provide the correct PSU for 220/240V.
Jul 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Curved red lies at top/bottom with some double vision in lines
This is from another fixya article but its relevant to your problem.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 25, 2008 | Samsung HCM5525W 55" Rear Projection...
Too much red + double vision viewing
This seems to be a convergence failure on your TV.
If you have hand basic soldering skills and a soldering iron, this might be something you can do.
Check this link for the parts you need.
Goo Luck.
Apr 02, 2008 | Samsung HCM5525W 55" Rear Projection...
Red lines taking over my T,V
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 26, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
275 people viewed this question
Henry  Thomas
Henry Thomas
