Question about Gateway FPD2275W LCD Monitor
2000 xp Gateway
Needs new hardrive and possible memory
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 49 Answers
You can purchase new hard drive from www.mundocorp.com
Posted on Aug 18, 2010
I formatted my hardrive and when i want to install Windows Xp it starts fine but then tells me that my hardrive is not installed,how can i fix this? "Setup did not find any Hard Disks Installed in...
Windows XP needs the SATA textmode drivers for it to recognise the SATA hard drive. This can be downloaded from this link:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2391
You will need the SATA AHCI driver
You must then burn the drivers to a CD or copy to a USB stick. When installing windows XP, you will be prompted "press F6" to load additional drivers, at this point the install will ask you to specify where these drivers can be found, if you direct it to the USB or CD Rom (USB is better to avoid disc swapping), it should find the drivers needed and then recognise your hard drive.
The above is a bit academic though, because this does not appear to support Windows XP according to the downloads options on the link
Jul 21, 2011 | Gateway T-6321 PC Notebook
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
Missing local area network
It is possible that the drivers for your modem, or wireless card that you have in your computer wasn't on the disk that you had. That came with your comptuer that you installed on your new hardrive.
go to http://drivers.com/
They have a Free Driver Scan program that you can scan your comptuer, see if your missing or need to update any drivers for what you have. Then you can download the drivers for free.
Good luck.
Please rate me, and give feed back, or recommend me it be much helpful.
Oct 03, 2009 | Gateway GT5058 Desktop PC
Reinstalled windows xp on a split partition resulting memory prob
You should just be able to boot off the Windows XP cd and perform what is called a clean installation. This will format the drive and give you access to all 160 gigs of drive space.  Seems like you've already lost all your data, but that's where to go.
Apr 01, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Disk boot failure
Technically you can copy all the data from one to another hdd but not the operating system
You have to install your operating system (windows, linux or MAC) on your new 500gig hdd and then copy your data from 60gig hdd.
Regards
Jan 22, 2009 | Avanquest DISK COPY & CLEAN (WIN...
Old gateway essential 400c PC
yes, a 400 mhz processor can run windows xp, but you will want to have a LOT of ram. i would not recommend it unless you have at 256-512 or more ram.
windows 2000 can get along with 128-256 ram.
Sep 20, 2008 | Gateway Essential 400C SE PC Desktop
Upgrading
goto the gateway site and check what memory type you need.
If you upgrade to 1064Mb that will increase the performace of your machine
Apr 20, 2008 | Gateway MX3228 Notebook
I want to know if I can upgrade the harddrive and memory
Depending on the memory you already have you can install upto a maximum of 1GB 266MHZ DDR, and cannot see any reason for not being able to upgrade your hardrive for a bigger one, but be aware that the Operating system backup will probably be on a seperate partition on your current hardrive, unless you got an installation cd with your laptop.
Oct 12, 2006 | Gateway M305CRV Notebook
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
