I have a LCM19v7 Westinghouse computer monitor, less than a year old. I have to turn the monitor on and off a dozen times before it stays on. Is there something I can do to fix or do I need a new monitor. If that is the case, it sure will not be a Westinghouse brand.
  • Terry Arnobit Jr Nov 01, 2008
    what is the problems and how do I fix it?
    I have several of these monitors, not even a year old and there is no picture but there is power going to the monitor. Does anybody know how to fix these?
  • 749 Answers
Exercise the warrantee before it runs out.
Posted on Oct 06, 2008
Lcd model L1928NV takes 2 to 3 dozen times turning on and off to get image stays on momentarily or stays on at times get message "no signal input" any ideas
doug_karr, Well, Why don't you get inside the monitor and find the "thermally sensitive/intermittant, cold, frosty looking" solder joint on the "switch-mode-power-supply"/"CCFL inverter supply" and do a nice touch-up job of resoldering it. Also look for FAILED, SWOLLEN, looking electrolytic filter capacitors and replace them with new ones if required. Read my fixya profile for all your options. Good luck guy.
12fixlouie aka louie12fix
Jan 10, 2010 | Westinghouse L1928NV Monitor
Westinghouse monitor lcm 17v8 will not power on it just sits there and blinks
mufdvr6942, the "switch-mode-power-supply" is in shutdown. Have a technician evaluate (inspect) it. Do that if monitor is less than 4yrs old.
Also visit youtube and search and view longer (8-12min) vid clips of LCD monitor disassembly or LCD repair FYI 12fixlouie
Nov 10, 2009 | Westinghouse Computers & Internet
I-Inc iF191D wont stay on
You have a blown power supply. If it is less than a year old its under warranty, send it in for repair. If it is out of warranty our site can show you how repair the internal power supply. Our site is :
www.ccl-la.com/badcaps.htm click on the link at the bottom for monitor repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 24, 2009 | Hannstar I-Inc iF191DPB 19" LCD Monitor
Moniter doesn't stay on
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you have additional questions just email me. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 10, 2009 | Samsung SyncMaster 225UW 22 inch LCD...
Turn it on get picture for 1 second then black
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm We also have a step by step dis-assembly and repair guide for the Westinghouse monitors posted there. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Jul 26, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
