Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Monitor 2001FP Blank Screen
When the monitor is powered up it will flash the Ultra Sharp Logo then nothing. If it is connected to computer it will stay awake but just a blank screen. If not connected to computer it will go to sleep within a few seconds with the green light turning amber. Can anyone help us with this problem?
Thanks,
Mark & Tina
I have to ask.......  Do you have it on the D-Sub position (if running VGA) or the DVI-D position (Running HD mode)?  If it's in the wrong input position (there are 4 available),then the monitor will look like it's working but the screen will be blank (act exactly as you describe).   If you have it on the right input and still have a blank screen, then I have to agree with Pulliam.
Posted on Jan 24, 2009
From your description your backlight is going out. The fluorescent light when it begins to burn out tries to draw too much power. Your inverter is sensing this 'too much' power draw and shuts down power to the back light. Replacing the backlight is the most technically difficult repair of an LCD, and most repair shops don't even offer this service. I recommend that you sell your LCD 'AS IS' on eBay or a similar website. The Power board and the Control Board are both usable parts that can be easily salvaged from most Dell Ultrasharp monitors.
Posted on Oct 11, 2008
Dell UltraSharp 2001FP (Gray) 20.1"
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
Feb 09, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Monitor 2001FP has a circular power supply connection Where can i get one of these??
They are on e-bay for very little . Just type in 2001fp an you will get people who have new power supply .
Feb 08, 2011 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell Ultra Sharp 2001FP LCD Monitor has a green horizontal bar on the screen.
This is because the LCD is not getting power through to that section of the grid. Sorry, it can't be fixed unless you have an electronics engineer you can take it to and given that it is electrical failure on the grid and not the actual crystals which are burnt out/damaged.
Feb 25, 2010 | Computers & Internet
My new Dell flat screen monitor is blank and posting a message - entering power save mode- ... when I restart it briefly displays the Dell logo and other normal display at normal startup then switches to...
You'll need to troubleshoot a little. SOmething may be broken, but you'll need to find out what. 1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one. 2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken. 3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop. If the PC will boot with another graphics card, the old one is broken. 4: If not, it may be your motherboard that's broken. Repeat step 3 with it. These steps should fix your problem. If not, please post back here. Regards, Yannick.
Jun 07, 2009 | Dell E193FP 19" Flat Panel LCD Monitor
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell 2001FP Monitor Problem
I have seen many of these. It appears the video processor board is dying or dead. You can replace the board or the monitor.
http://www.lcdrepair.us/2001fp-logic.html
This is the board. Not to hard to replace if you have some tech ability.
Oct 05, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell support , would recommend you to buy a new monitor because , they donot do any repairs on the LCD monitors., except for exchanging them, if they are in warranty. You can try the following people , they do repairs on dell flat panels
Thanks
proton
Aug 02, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 2001FP always in sleep mode.
I have a dell ultrasharp and at first it would not come on at all. Open it up and found loose connection on plug connectors 3 pin. Soldered and would come up but blinks in and out sometimes take longer than other times. Big Capacitor when open up Power supply was leaky. Check for bad caps
Sep 08, 2007 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
726 people viewed this question
Alun Cox
