Question about GE JKP45 Electric Double Oven
GE double oven - bottem will not heat, top oven fine
Did you find a solution to the oven not heating? I have the same problem. The bottom oven control seem to be fine. I can set the temperature then the oven would start heating at 100F and go blank.
Thanks,
Chuck
ruby3904@yahoo.com
  • mreid542
    mreid542 Oct 06, 2008
    top oven works fine. lower oven will not bake or broil. set control panel to bake and temperature just goes to 100 but nothing happens. elements show continuity. i think it may be the control because i get 240 out of the control for the upper oven but zero voltage out for the lower oven
  • awhite621 Dec 28, 2008
    Thank you DVS1936 - you are a life saver! This fix worked!! Saved me a service call
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Posted on Nov 02, 2008
  • 166 Answers
I ended up taking the control board out the the oven, took the board apart and found a loose connection (solder joint) on the bottom of one of the relays. resoldered the bad connection now the oven works fine.
Posted on Nov 20, 2008
Frigidaire pleb30t9fcc double oven -- top oven heats fine --- bottom oven does not heat up all the way
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 14, 2010 | Frigidaire PLEB30T9FC Stainless Steel...
Top oven works fine bottom oven won't heat
heatman101
Dec 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Nov 20, 2008 | GE JRP24 Electric Double Oven
GE Profile JT952 Double Wall Oven doesn't heat up adequately
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
GE JKP45 Electric Double Oven Logo
857 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
