Question about Toshiba Satellite M35X-S149 Notebook
Recovery freezes after "To continue press (C)"
Attempting full recovery from CD that came with computer. The first screen loads OK and I press F1 to continue. The second screen loads OK. The last line reads "To continue press (C) To abort press (A)" [C,A]?" I push C and it appears after the ?. The cursor moves to the next line but nothing else happens.
What might the problem be? Is there something else I could try?
  • 2 more comments
  • 1FREDEB Oct 10, 2008
    How do I do that?
    Note: I have used this recovery disk before without problems.
  • 1FREDEB Oct 22, 2008
    Sorry, I've been out of town. Here is the detail of my situation.
    With the recovery CD in the CD drive, I power up while holding down the C key and release it when the "In Touch With TOSHIBA" appears.
    First screen:
    Welcome to the Toshiba recovery utility.
    This process will restore the original default system install(ed) on your hard drive.
    Note that the current contents of your hard drive will be erased and replaced by the default system install. You should back up your system before continuing.
    By selecting OK, you are accepting the terms of the Microsoft end-user license agreement that appears in the Windows License Agreement Setup Screen.
    F1 = OK, F2 = Cancel
    I press F1 key.
    A quick flash of "Recovery in progress..."
    Then a bunch of XXX spell out "WARNING continuing with this process will erase the current contents of your hard disk drive and replace them with the original default system install.
    To Proceed:
    1. Insure that the recovery CD/DVD is in the CD/DVD drive.
    2. Keep the CD/DVD in the drive until you are asked to remove it.
    If you do not want to erase the the contents of your hard disk drive, then press 'A' to abort
    To continue press (C). To abort press (A)...[C, A]?
    I press C
    The CD begins to spinning the drive, then it stops. Nothing else happens. The cursor flashes in the lower left corner.
    The recovery instructions say "Once you have begun the process, do not attempt to stop it. You may seriously damage your system." This may have occurred, as I have tried the recovery several times.
  • 1FREDEB Oct 24, 2008
    I added all the details as requested.
    Brigadier General:
  • 6,966 Answers
Offhand, possibly a hardware problem, more specifically hard disc failure. Initially, determine if the HDD could be autodetected in the CMOS/BIOS setup. If yes, you might be better off removing said HDD from the Toshiba laptop and with a 2.5HDto USB adapter, hook it up to the PC you are currently using. You can run tests then on the Toshiba HDD to determine if it is still usable, with bad sectors. Doing so will also allow you to partition, format, scan and basically anything else required since it will be treated as an external storgae device. If everything checks out, then it can be replaced back to the Toshiba and the recovery resumed.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 24, 2008
  • Toshiba Master
  • 6,487 Answers
So it just wont continue in doing teh recovery or something happen when you just let it to continue the process? because if the recovery still worn finish for long time and just continue on spinning try to restart the computer and repaet again the steps..........
    Sergeant:
    Champion:
  • 435 Answers
Hi, Sounds like BIOS setting. Set it to defaults and try.
If it doesnt work, try disabling write cache in BIOS and try recovery.
I just hope that the HDD is not corrupt to cause freezing ...
Posted on Oct 22, 2008
    Genius:
  • 1,913 Answers
First boot your system with disk t.set your first boot as your cd rom or dvd rom infirsr boot otion in bios setup
u can enter in bios by press DEL,F2 orF3 or F8 F12 try from these key .
then if u sucees bot with disk then go to recovery console.
then type user and password if it prompt.
then type "chkdsk /r" in command prompt.then press "y"
then it restrart system then u can repaitr your operating system.
also recover the system.easily.
your hard disk has bed sector efect.
Posted on Oct 10, 2008
    Sergeant:
    Champion:
  • 334 Answers
U dont wann use rcovery cd ok u need xp home cd or vista boot form that then redo hard drive formatt ect ten update it config it all back in need help we can chat live im on yahoo and aim
  • 11 more comments
  • nick helpap
    nick helpap Oct 10, 2008
    what is problem your having anyways cant boot in vista u try safe mode f8 hold on start up disable sum stuff u did recently
  • nick helpap
    well thats not goona killa bug tho just recovering it u wantto redo it alll right way u need vista dvd ok or xp whatevre uuse does one those disk u have say vista on i t
  • nick helpap
    not all time they work ok depeing whats going on best bet getthat dvd ok or try booting into safe mode f8 uncheak all startups under msconfig go start in serch type in msconfig can u booot into safe mode
  • nick helpap
  • nick helpap
    tap f8 key during start up to it ask u boot in safe mode can u do that no recover cds in
  • nick helpap
    once in ther last know good configration or we can do restor to elery date hold f8 on start up
  • nick helpap
    are u on aim we can chat live im drummernick2002 yahoo msg is nick _helpap walk u throw this gona take sum effort
  • nick helpap
    or ask for live help then as for me nick helpap we can chat live thx
  • nick helpap
    on next line u talked about with ? on it type in word run or E:SETUp or try E:run whatever letter of cd rom is thats just to try dought that will work u need get in there in safe mode hold f8 on start up ok does it get u to optioon screen if not we need vista dvd or xp whatever os u use ok to do this right way
  • nick helpap
    she odnt have to she just did work with what u have just try f8 on startup 1st get back with me on here thx
  • nick helpap
    thats not her problem she can boot to recover y disk she just said u u other guys read dam
  • nick helpap
    acdr he or she just said they got in those disk man u nee dto read 1st bro thats not the problem we nee dto get this fixed not try same **** over agian
  • nick helpap
    chdisk will not fix this sort of issue if u know computers she need orgianl vista dvd or try f8 safe mode get in ther ten we can restore the windos to elery date or try msconfig uncheak stuff form starting up cuses problems or get orgainl dvd vista or xp boot into that then formatt hard drive clean or reinstall ove rit save old info
  • 1,879 Answers
First screen - is is showing you the BIOS ? and what is the message on the screen why is it asking you to press F1 to continue. Normal booting does not ask you to press any key to continue.
"To continue press (C) To abort press (A)" [C,A]?" - again there should be a message / information prior to this option that is presented to you. usually with this message, can't locate OS boot information.
provide additional and detailed information.
Posted on Oct 05, 2008
  • Toshiba Master
  • 5,568 Answers
It wasn't Toshiba, but I had three complete sets (8 disks each), one original and two new replacements of HP/Compaq recovery disks and after checking all three, finally got ONE set of 8 with no unreadable files on any disk. CDs aren't infallible even if new; I would advise checking the recovery disks before getting too angry at the Toshiba.
You can get Emsa DiskCheck freeware here:
http://www.softpedia.com/progDownload/Emsa-DiskCheck-Download-10830.html
I have used it a few times now to ascertain whether disks are readable or not.
    Brigadier General:
  • 3,614 Answers
First try to reset or restore the CMOS/BIOS setting of your unit. this can correct the problem.
let me know again here.
  • micromaster
    micromaster Oct 10, 2008
    You must go into the CMOS/BIOS settings, see to it that your device detected a HDD attached to it..
    let me know if your HDD was detected on your primary drive.
    Scholar:
  • 155 Answers
Can you give the label on the recovery cd?
  • 1 more comment
  • Rachelle Aviles
    Rachelle Aviles Oct 05, 2008
    Repeatedly tap F2 after turning the computer on. Go to the boot sequence section and change it so the cdrom device is on top of the list. Apply the changes and reboot the computer. It should let you boot from the cd when you restart.
  • Rachelle Aviles
    Let us know if it didnt work. Otherwise, please dont forget to rate the solution that fixed it. Thanks!
  • Rachelle Aviles
    With the cd already inside, try powering the computer on while holding down the c button.
Reset to factory default settings
which operating system ??
Shut down your computer and restart it.
Watch for the Compaq logo, then press the "F1" key to enter setup.
Press the right arrow within setup to go to the Boot menu.
Press the down arrow to access the "Boot Device Priority" option.
Change the first boot device to CD-ROM by pressing the down arrow until "CD-ROM" is displayed.
Eject the CD tray and place the recovery CD that came with your computer into the tray.
If you do not have a recovery CD, you can order one directly from Hewlett Packard.
Shut down and restart the computer.
The Presario will automatically boot from the CD and begin the recovery process.
Select the operating system your computer shipped with.
Many Compaq recovery CDs support multiple operating systems, so be sure to choose the operating system your computer shipped with.
Insert the operating system CD when prompted.
Enter the license key for the operating system when prompted.
The license key is typically found on a small tag located on the top or side of the computer.
or
There are multiple instances when you would want to wipe your PC's memory clean and reset it to the factory defaults.
Called "formatting," it is often the last-ditch effort to restore a PC to functionality.
You will also have to format your PC if it gets crippled by viruses.
Although these instructions are for the Compaq Presario, the steps are essentially the same for all Windows-based PCs.
Be sure that you want to delete everything--this process is irreversible.
Back up any data that you want to keep by saving it to removable media, such as external hard drives, flash drives, DVD-R, etc.
Unplug all peripheral devices, except for the keyboard and mouse.
Turn on the computer.
As the computer is starting, repeatedly press F1 to initiate the recovery process.
When the BIOS setup screen appears, press the right arrow key to select "Boot". Press the down arrow key to select "Boot Device Priority" and press "Enter".
Press the down arrow key to select "CD-ROM" and press "+" to move it to the top of the list.
Open the CD-ROM tray, and insert the system recovery disk.
Exit the BIOS setup by pressing "F10". Be sure to select "Save Changes and Exit".
System recovery should initiate.
If it does not, and the PC loads Windows, then you have either failed to set the CD-ROM at the top of the boot priority list or you exited the BIOS setup without saving.
Press "R" to begin the recovery process.
When prompted, select "Full System Recovery".
Restart the computer when the process has completed.
Jun 25, 2013 | HP Compaq Presario SR2150NX PC Desktop
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
My copm will not start, it starts with safe mode or continue as previous the copm runs for about 30 secs if not used for a while goes as far as xp loading then turns off. if i try and start again it turns...
Put the recovery CD in the DVD drive and at the first screen press del or f1 so that you can setup the Boot order. Make sure CD/DVD is on the top. You have to reinstall windows to get your computer working. The Dell recovery Disk will erase all data on the hard drive if you use it.
May 19, 2011 | Dell Dimension 2350 PC Desktop
Its not loading to windows, what should i do?
If its not loading to windows,check first what would be the error message or to make it more easier try to reinstall the Operating System of your machine, just access the recovery manager. Hope it helps. =)
AnEspera
Apr 18, 2011 | HP Pavilion dv6000z Notebook
My husbands ex wife bought my step son a used HP compaq d530 SFF desktop. She set an admin password on it and now she cant remember what it is. Is there anyway to restore it back to the factory settings...
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) also
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps
Hope this helps
Apr 08, 2011 | Compaq Computers & Internet
How do i restore my hp pavilion dv 5000 to factort setting?
There should have been a recovery disk created or included when you bought a laptop. Insert disk if you have it and restart your computer with the recovery disk in the CD drive. Make sure all your documents and personal data are backed up. When the computer restarts it should start restoring your computer to the factory default. There will be a wizard to guide you through the process.
If there is no disk or got lost,then follow this steps:
1.Save any files or folders on your computer with flash drives. Drag and drop files onto the icon of your flash drive.
2.Go to "Start" > "Restart" to reboot your netbook.
3.Hold down "Alt" and "F10" when you see the logo on the screen. The recovery menu will load.
4.Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your computer back to factory settings. Follow the instructions on the screen.
5.Choose your time zone and language when the customization menu appears. Reboot when you are prompted.
6.Restore your saved files from the flash drive.
hope this helps,Goodluck..pls response with your rate and testimonials below for further issues..thanks
Feb 23, 2011 | Computers & Internet
How to reset to factory settings a toshiba satellite A305-S6829 with Vista ? (pressing 0, or F8 didn't bring me far!
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Note that this erases all data, and reloads all factory default software. Be sure to back up all your important personal data beforehand!
Dec 31, 2010 | Toshiba Computers & Internet
My computer, a lenovo y510 laptop malfunctioned. After inserting the recovery, and attempting to boot from the disk, the screen simply goes blank instead of opening the normal vista install center.
Hi lightning_ha,
Based on your situation, I suggest trying the following steps:
1. Turn on the system then insert the recovery disk inside the ODD.
2. Now turn off the computer while recovery disk is inside.
3. Turn on the computer, the moment you press the power button, immediately tap the F12 key and press it continuously.
4. Now you have the boot option. Select CD/DVD/ODD by pressing enter then continuously tap it until you see the Windows is loading a file.
5. Wait until it goes 100%.
6. Now it will ask you on what partition you will put the operating system. Just select the partition that has a large capacity or size.
7. Just wait until it completes the whole installation.
8. Restart the computer.
Hope it helps,
Oct 06, 2010 | Lenovo IdeaPad Y510 Notebook
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
Toshiba Satellite M35X-S149 Notebook Logo
130 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
