Pioneer cd tuner deck model xc-is21t missing lead
I have the above cd system and have lost one of the main leads to the system.
i have searched the internet and cant find anywhere to get the required part that is needed.
all i can do to explain the lead is that its the main lead that links the cd deck to the amplifier and its has a square connector on both ends
any help on this matter ie a part number or a place as to were i can get this part would be very appreciated thanks and look forward to hearing from yoiu
Go to www.donberg.ie and search for ADE7039 CONNECTING LEAD , order code piac 173
Posted on Oct 14, 2008
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
MI EQUIPO DE CASA PIONEER CD TUNER TAPE DECK XC- 1521T ESTA BLOQUEADO
tengo uno igual pero al encenderlo y subir aunque sea a 1 se escucha el sumbido del voltaje q puede ser
Aug 20, 2012 | Pioneer Audio Players & Recorders
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
How to connect a pioneer super tuner to a 91 honda accord
With a DC voltage tester, check the two power leads for 12+ volts and proper operation, and be sure the unit is properly grounded.
The two power leads are,
1.Constant feed: which should be connected to an un-switched power source that delivers continuous
power to the units memory.
2.Switched feed: which should be connected to a switched power source controlled by the vehicles ignition switch.
Before installing in dash check unit for proper operation.
Good luck
Aduz
Mar 27, 2009 | Pioneer DEH-P2900MP CD Receiver...
Missing Antenna lead
find an unused or broken stereo, and use the one off it
May 17, 2008 | Pioneer DEH-P9600MP CD Player
Malfunctioning Pioneer XC-IS21t
I'm not sure what that could be but probably the amp. section. I have a xc-is21t, that came out in year 2000, I use it almost everyday, and it works excellent. Unfortunately a friend of mine has dropped the whole unit on the floor, and guess what it's still works perfectly, only problem the sliding door for the cd(but only the see thru plastic part) is broken and I'm not sure where can I find this part. I wrote a letter to Pioneer.com, so hopefully they can locate the part for me. The only problem with this model that it doesn't play mp3 but again this was only made in year 2000.
Jan 02, 2008 | Audio Players & Recorders
Amp problems
did you run your 12+ to the battery? did you supply a sufficient ground of least 2x the size of the power lead?..did you hook up to the amp turn on lead and NOT the power antenna? model numbers of radio and amp would really be helpful...my email is troublerst@hotmail.com send me specifics and we will work it out
Nov 07, 2007 | Car Audio & Video
Record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
Sep 29, 2007 | Audio Players & Recorders
594 people viewed this question
 Grubhead
Grubhead
