Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Light flashing and tv won't turn on
I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
  • rushinghome Oct 30, 2008
    I have the same exact problem - does anyone have a possible answer?
  • buttrfly_5 Dec 27, 2008
    I have the mitsubishi hdtv 48" 1080 and it will not turn on. The green flashing light is the only thing it does. We tried fixing it ourselves by changing 4 1000uf 16 v capacitors, but still nothing. Any suggestions on what else I can do to fix this BIG problem?
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Posted on Nov 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: I have a Mitsubishi HDTV 1080, model #WS-55511 and the green power light is blinking on and off. We've used the paperclip to reset the machine and it doesn't work, and we've unplugged the power supply
replace the capacitors on the DM board. Heres a link to the repair kit which contains the replacement capacitors and instrucions of how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on May 11, 2009
SOURCE: flashing green light
I had the same problem due to power surge.Repairman came and said power board replacement might fix--$300 parts and labor, but if DM module is damaged, another $600-700. My set is 5 yrs. old. I'm shopping for a new LCD.
Posted on Jan 09, 2008
  • 80 Answers
SOURCE: green light flashes on my 65 mitsubishi 1080
You need to replace 4 capacitors on the "DM" board. They are 1000uf and 16v. The board is located under a metal shield on the left side of the set (looking from the rear).
Posted on May 21, 2009
ladywinn
  • 5138 Answers
SOURCE: my 65 in mitsubishi medallion hdtv 1080 wont turn
Fisrt try resoldering your Boards then Ck pico fuses they are green or yellow look like resistors but are fuses 5amps or 6amps also you may need to replace Both of your STK ICs they are Big Black ICs will have Part number on them example STK392-570 Call Mats For these 1-800-628-1118 Go by number on your STKs
Posted on Nov 18, 2009
Testimonial: "excellent knowledge and communication! "
  • 11800 Answers
SOURCE: Lost power last night, now
Not very much - when the power was lost a power spike happened and this spike has fried some components from the power board: the blinking light signals that the protection system of the source has detected an overload on one of the outputs and has shut it down to protect it and the rest of the tv The only way to fix that is to open the tv and test the components. This is a job for someone who has done this before and has at least a basic understanding of electronics. If you're not such a person then it's time to call one, no way around that.
Posted on Nov 13, 2010
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Yesterday we had a power outage. When the power came back on, my TV would not work. The green light on the front just keeps flashing quickly. I tried unplugging it, and I unhooked all devices from it as...
Thats caused by weak capacitors on the DM board. They drain when the power is lost then they cant recharge after power is restired. You can get the dm repair kit for your model at www.tvrepairworld.com it contains the repair instructions and the upgraded caps plus other service info on the cd
Jun 07, 2011 | Mitsubishi Televison & Video
MItsubishi HDTV 1080
need to call a servicer, if they found out that if this is a chassis issue, call mitsu
Sep 20, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
you might want to have the power transformer checked to make sure its working correctly.sometimes when they go bad all you get is the flashing light
Oct 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi HDTV 1080 WS 73713
Have you tried to hit the reset button on the front of the tv?
May 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green power on light flickers
I can help if anyone with this problem lives in Anaheim CA.
Jan 12, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
1,129 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
