Question about Bissell 1200B Handheld Steam Vacuum
Little Green Machine not spraying water or sucking up, but motor running. Help!!!!
Green Machine running, not spraying water or sucking up water. Please e-mail me back allyoopspeckles@yahoo.com. Thanks, Pat & Jim Rogers.
SOURCE: little green machine
Just got mine to work today, same problem. Took it apart by takimg the back off.In the very bottom of the machine is a small pump motor about 1 1/2" diameter X 1 1/2" long. I slid this out and removed two screws holding a plastic strap around the motor to remove it. The motor was siezed so I spun the shaft free with pliers and reinstalled it. now it pumps water through the hose. When re-installing the motor to the pump be aware the shaft has a flat spot that must mate the plastic pump properly. Also you must first remove the large vaccum motor at the top. Total time under one hour. Hope this helps. Cat.22
Posted on Sep 29, 2007
reddevil6
  • 1673 Answers
SOURCE: bissell little green steam machine
There is a small pump inside the unit that may be bad.
Posted on Feb 05, 2008
The pump motor solution worked on my Bissell 1400. I did not have to take the vacuum motor out. I also lubed the motor although it looked like it might have sealed bearings, figuring a little WD 40 couldn't hurt.
Posted on Mar 08, 2009
SOURCE: my little green machine won't spray the solution but it will pick
We had the same problem. After dissassembling the whole machine we could not find a clog or any other obvious problem. The manual suggests priming the pump by putting the solution reservoir in and out a few times. This did not help much. What did work was to raise the unit up a few feet above the trigger while depressing the holding the spray trigger. (That is, use gravity to fill the tube.) After solution was flowing freely, we turned the machine on and it seems to spray fine again.
Hope this helps
Posted on Jul 22, 2009
  • 3 Answers
SOURCE: I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (
I got my Little Green ProHeat when the product was first unveiled several years ago. Shortly thereafter, the nozzle itself developed a clog in the spray jet. Remove the nozzle from the end of the hose, and with the machine running pull the trigger. If a great amount of solution comes out of the supply hole, then your nozzle is clogged. You can try clearing it with a very thin pin and then rinsing it out.
In about 6 months, my pump would no longer spray solution at all but I could hear the tiny pump still running inside the machine when I would pull the trigger. Remove the tanks, unplug the unit, and look carefully and you will see the few screws holding the unit together. Pull it apart carefully and don't use much force as some of it snaps together and you don't want to break those tabs. Once open, you can find the solution pump, a little fella. The drive shaft on the motor that spins the pump had rusted away completely! Design flaw. In lieu of getting it repaired, I simply started using a spray bottle for my solution application. Several years later and I'm ready to take the time to replace the pump - a very simple process. From the research I've done, the part number for the solution pump is:
Manufacturer's Part Number: 6035029
If you google search "Bissell 6035029 VacPartsWarehouse" without the quotes, you should find your part there for around $9.
Try this direct link to VacPartsWarehouse's website:
VacPartsWarehouse Bissell 1425-2 Little Green ProHeat
Click item #9. It's very simple to install. If you can wield a philips screwdriver, and pay attention to how you've disassembled the unit and then just reverse the steps, you can fix this yourself on the cheap.
Good luck! :)
Dan
Posted on Sep 12, 2009
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Bissell little green machine will not spray
Sincerely, CRTN
Mar 22, 2010 | Bissell 1425 Little Green ProHeat Handheld...
I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (ie on...
Good luck! :)
Dan
May 29, 2009 | Bissell 1400 Little Green Pro Canister...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
I also had the same problem as you.
Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
I did this a couple of times and it worked. This info I found on the Bissell website.
Good Luck!
Aug 15, 2008 | Bissell 1425 Little Green ProHeat Handheld...
I need directions for using the Bissell Little Green.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723971
Generic problem for all Vacuums
Posted by jkcanger on Jun 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the instruction did not come with the Bissell Little Green Machine then I would contact the Bissell Factory that I will provide for you listed 2 the bottom of the answer,
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
Bissel Little Green Spray Motor
Motor was seized. Probably from lack of use combined with the moisture involved with such a device. I loosened the motor with a pliers, gave it a small shot of wd-40, and off we go. Works fine.
Mar 09, 2008 | Bissell Vacuums
Hoover steam cleaner
Is it spraying and sucking up ok? Check the filter inside the dirty water tank, it needs a 1/4 in. gap from the top to the top of the filter. If it isn't spraying out a good stream along the bottom, maybe running a mix of vinegar and water may clean out the lines to help it spray better.
Nov 02, 2007 | Hoover F7431-900 SteamVac Vacuum
Little green machine
Sep 23, 2007 | Bissell 1200B Handheld Steam Vacuum
Bissell 1200B Handheld Steam Vacuum Logo
214 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
