Question about Dryers
Have a hoover hnc 380 tumble dryer makes a noise on reverse spin
5 Suggested Answers
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
vickygomar
  • 460 Answers
SOURCE: Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
Posted on May 15, 2009
SOURCE: My hoover tumble dryer hnv
TheOsteopath is a pure genius - have had an increasingly noisy hnv 380 and was about to get the yellow pages out for an expensive repair (or replacement) but followed the instructions to the 't' and it works perfectly. Many many thanks. You've saved my pocket and my eardrums. JS.
Posted on Jun 28, 2009
  • 691 Answers
SOURCE: beko tumble dryer was making strange noise now no
How old is your dryer? strage noise usually take place if the unit is old and worn out. I dont know of any washer or dryer doesn't make noise after years of using. The more you use the more ware and tear and noise come from the unit. Noise can be the belt loose or tumbler padding or flange, connected to a simple bushing is worn out, making the unit woobily noisy. No heat mean your heating elements probably burnt out need replacing which will cost 80-100 bucks. its fairly easy to replace once you remove the back cover. To find out what making that noise, the best thing to do is run the dryer with the back cover off by look and listhen and see what making that noise.
Posted on Jul 08, 2009
SOURCE: White knight tumble dryer making
I have this banging problem, it sounds like a plastic ball rolling about inside it
Posted on Dec 02, 2009
Hoover tumble dryer vhv 380 filter care light constantly on even thou there all spotless .....please help
Please vacuum the lint filter housing and check the outside vent on your house for any lint build-up.
Oct 16, 2015 | Hoover Dryers
Have a 6kg hoover tumble dryer making noises when on sounds like something trappped under drum
it sounds like your bearing are gone you can buy a bearing kit its not an easy job but if your a handy man or woman it can be done
Jul 29, 2014 | Hoover VHC391 T-80 Dryer
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
MY HOOVER HNC 175-80 TUMBLER DRYER IS MAKING SQUEAKING NOISE
it could be that you need a new drive belt or it's the idler wheel that is under the drum.just put some wd40 on it
Nov 03, 2011 | Dryers
Hoover HDV 7 FM tumble drier. The drum is not turning (its making a loud buzzing noise like its trying to get going) and the filter light is on, although that is free from fluff. Is it time for a new drier...
sumanth m 's answer may well be correct because I have the same dryer and it has the same problem. I got a massive electric shock off mine and so I think the buzzing is a protection measure against a short circuit
Feb 15, 2011 | Hoover HDV7FM Electric Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
thank you
May 14, 2009 | Dryers
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
Mar 14, 2008 | Dryers
Dryer stuck in sensing mode
Since no help was available without premium assistance, I actually contacted a repairman. He performed all the tests again and told me the problem was the control board. Then wanted $600 to fix. I found the part online for $150 and fixed it myself in about an hour. Instructions were easy.
Sep 08, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
