Question about KitchenAid Dishwashers
Dishwasher: KUDL02IRBS1 WORKING FINE. NEXT DAY, PRESS START BUTTON...BLINKS, NOTHING FURTHER HAPPENS.? ANY IDEAS?
  • 2 more comments
  • rahard Oct 05, 2008
    It is a 2 year old Kitchen Aid dishwasher. used only about 50 times. ran well all the time.
    suddenly, this morning, it decided to blink at me, and stop functioning beyond the blinking
    i opened the panel.
    disconnected first the pink and black wires that are plugged into the computer module. the wires here are the same color as the wires that go to the control panel in the door handle. the NORMAL green lite went off. I plugged the wires back in. Pressed NORMAL, the green lite began to blink again. I went thru this procedure three times. same results.
    Next procedure: press the NORMAL button. Green lite starts blinking. Then i disconnected the other plug with 4 wires to the computer module. NORMAL lite went off. Plugged the plug in. Normal lite when pressed began blinking. No further action. repeated this procedure three times.
    thats all i did. what now? john
    did you read my comment previously?
    i thot you were the repair person?
    should i go ahead and purchase the parts mentioned ....switch, actuator?
    what would calling in an expensive repair person do that you cannot do? tell me the same thing probably? and install the parts himself?
  • rahard Oct 06, 2008
    Irish druid....hi. this is rahard (outside of Galway, near Athenry)
    need clearer understanding of some words: Door Switch, for example. If you can go to this web page:
    http://www.easyapplianceparts.com/MultiM...
    you will find a parts list for the dishwasher we are talking about.
    it lists various parts. can you tell me which ones you think I will need from that list?
    because the Normal button lights up, I will assume there is electricity.
    so, perhaps the actuator? the actuator could be a 'switch" as you noted, couldn't it?
    till i hear again from you...john
    President:
  • 2,712 Answers
You'll have to check the following:
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
If all these seem OK, then you'll have to get a repairman to run tests and accurately diagnose the problem. Unfortunately, all we can do is provide a long distance evaluation and all possible troubleshooting steps. The actual repairs will have to be carried out by you.
Hope that helped!
Posted on Oct 05, 2008
  • Swilin Sampson
    Swilin Sampson Oct 06, 2008
    THIS is the door switch I am talking about. But depending upon the exact component that is defective, it could be either this or this as well..
    However, these are only suggestions. It could be that these parts are still in working condition in your washer, and only a slight alignment adjustment may be required. I wouldn't recommend simply going ahead and buying all the parts mentioned here. I have just given all the possible causes for the issue. It would be impossible to say exactly what is needed without conducting a manual inspection. Hence, I would really recommend getting a repairman out to take a look. At least now you have an idea what to expect, instead of getting fleeced by the mechanic :)
    So you're from Galway? Nice city..was there in January last year. I'm staying in Dublin myself. Drop me a line if you're ever round here!
    Cheers mate, and I hope you get the issue sorted out!
    IrishDruid
    Brigadier General:
  • 3,614 Answers
1) Be sure the power is on, the door is latched, and the control is turned on. Also make sure the appliance cord is plugged into the electrical receptacle under the sink (some are hardwired and don't come unplugged).
2) If that doesn't solve the problem, the door switch, the timer, or the selector switch may be defective. To solve the problem, you may be able to adjust the door latch's strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it).
3) If that doesn't work, call an appliance repair person.
  • micromaster
    micromaster Oct 05, 2008
    yes i'am but i cannot actually do the fixing and assembling it personally.. i have advise you to call someone near your place someone who can do the actual job for you, if you have no idea or background experience working on that appliance.
    here we give help and fix the problem, but we not always instruct you to self serviced the unit just to avoid any further damage and danger to.
  • micromaster
    let me know again here..
Dishwasher is a whirlpool DU940QWDB3. When yu press button to start washing, lights go on but nothing happens. Where should i start trouble shooting this? Thanks
Dear Sir:
see the wiring diagram attached.
1) I recommend the switch door, if are open the machine will not close the starting relais as you will see in the diagram.
sincerely. God bless you.
May 07, 2012 | Whirlpool Dishwashers
My Kenmore dishwasher, model# 665.1357K700 has quit working. When I try to start the dishwasher any of the cycle buttons I choose will rapidly blink and nothing happens if I try the start...
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 01, 2011 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kitchen Aid dishwasher won't start
If the power indicator is on check the latch as alot of the kitchen aid dishwashers wont start if the latch is out of alignment.
Jul 02, 2008 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Sep 10, 2007 | Maytag MDB7100AWB Dishwasher
Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Jun 11, 2007 | Whirlpool 24 in. GU2548XTP Built-in...
Dishwashers Logo
144 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
