Question about GE DCSR483EA Electric Dryer
REPLACING THE BELT
I know the belt needs to be changed but i cant get inside the dryer to change it. I dont have a manual anymore. how do i remove the shell to get inside of it?
  • Anonymous Dec 16, 2008
    having problem getting enought tension on the belt I think. drum doesen't turn.
  • 943 Answers
Hi thanks for the question. to replace the belt. open the door. screws on the inside, under top. remove screws . lift the top. 2 screws on the inside, of front panel. remove. pull front off. now replace the belt. thanks the appliance doc. please rate me. thanks
Posted on Oct 06, 2008
Belt replacment
Here is a diagram from kenmore corp. that should help you out
Maytag Dryer Belt Routing
This is the most common belt routing found on most Maytag brands clothes dryers.
Since you will have everything disassembled to change the belt, this is an excellent opportunity to vacuum out the cabinet to remove dust and lint and perform preventative maintenance on your dryer. When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Dec 04, 2009 | Kenmore 66862 Dryer
Does not spin/tumble
sounds like a broken belt.remove two screws at lint filter .pry top up at front and lid should lift and hinge back.should see belt or mark on center of drum.remove two screws holding front panel from inside cabinet.lift the front panel off two clips on front of unit belt probably laying in bottom.change idler pulley too.hope this helps please rate my solution:)
May 31, 2009 | Dryers
Replacing a belt
Hi, To replace this belt, UNPLUG the dryer. Remover the screws under the lint screen. Insert a flat blade screw driver in the gap between the top panel and the front panel and pry up the top panel.
Now locate the screw inside the front panel in the upper corners. Remove them and the front will lift up and release.
Now you will be able to change the belt. Follow the instrutions included in the belt packadge to thread the belt throught the idler pulley.
You can get the belt from my web site @ www.whirlpoolpartssurplus.com if you would like.
Part# 8066065
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Whirlpool LER7646J Dryer
Dryer wont turn inside but gets hot and turns on
If it's not turning at all, the belt is probably broken. If it turns a little and then stops, the belt is slipping. In either case, the belt needs to be replaced.
May 11, 2009 | Dryers
How do i?
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Apr 05, 2009 | Kenmore 63942 Dryer
Hotpoint condenser tumble dryer model tdc30p belt replacement
You will have to unplug the dryer and remove the front panel with the door, mark and remove the wires to the door switch, then there should be two screws on the inside which you will need to remove then tilt the panel out and lift to disengage the tabs connecting it to the main cabinet. Then you should be able to remove the old belt, carefully lift the drum and slide the new belt under it. Then this is where you will need to be a contortionist and take care as there are many sharp edges under there. Locate the motor and tensioner pulley, place the belt around the tensioner and while pushing back against the spring on the tensioner hook the belt to the motor pulley, then move belt on drum so it is aligned with lower pulleys. Turn the drum by hand a couple of times to make sure everything works.
Apr 04, 2009 | Hotpoint Dryers
Dryer does not turn anymore, dried shoes inside
the belt that turns the drum has broken or come off
you will need to remove the housing and replace the belt or call for service
Good luck
Jan 07, 2009 | Kenmore 62602 Electric Dryer
How to change a drive belt on a candy CDC266 tumble dryer
don't know what make you have but if you go to sears .com click on parts put in your model number(inside dryer door)you will find a break down of everything you need to know,let me know how you do-mike
Oct 12, 2008 | Candy CDC266 Dryer
Whirlpool dryer
reinstall back.. remove 2 screws under lint screen press 2 clips on front corners with putty knife lift top remove screw on each side top inside front lift front off belt goes over drum ..double it and pass through idler support arm then onto motor pulley ..belt pack may have a diagram
Jul 31, 2008 | Whirlpool Dryers
Hoover upright windtunnel isnt propelling itself anymore
If the V belt is loose with the handle down, then maybe the idler wheel under neath the belt isn't contacting the belt, may be jammed down, just push on it to see if it moves up and down. Belts don't last very long, you may want to replace both of them.
Dec 29, 2007 | Vacuums
GE DCSR483EA Electric Dryer Logo
154 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
