Question about Archos AV 500 Digital Media Player
Hard drive is broken
My hard drive is broken and i need a new one. where can i geth this from? x
You need a 1.8" zif format hard drive samsung and toshiba both have models that will work for you, but you need to do a downgrade upgrade trip with the firmware in order to get the archos to use the new hard drive! her is the link to how to do the downgrade upgrade to the firmware
http://frenchyaz.com/av500.aspx
Posted on Oct 09, 2008
Repair broken
Easy, just hook up old drive as secondary and new drive as primary. Copy what you need from the secondary onto the primary. When you are done, just disconnect the secondary drive and enjoy your new one.
Dec 28, 2013 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
Broken connecting pin on the hard disk
From my experience, it is not even close to cost effective to try and repair a hard drive with a broken pin. A new enclosure/board would have to be purchased and that board would have to be a match to the one you are pulling for the hard drive to be usable. This all needs to be done in a clean room.
It would cost hundreds less to just replace the drive.
Backup, backup, backup, and then when you are done with that backup again.
Mar 21, 2012 | Computers & Internet
A small device that connects to the hard drive is broken, so the pc can't boot up
in every computer need hard drive for storing data and software date in your case which device your trying to connect is must know and then in your question is not clear which one is broken any way listn my answer
in case of hard drive broken then need to replace new hard drive other wise device broken then no need to worry you must place device in front usb port or back usb port
in case of your hard drive is good then you needt to restart your computer and then press F5 continously that will help to open your pc
Feb 22, 2011 | Gateway 510 X (10272197) PC Desktop
Usb input from hard drive to computer is broken
Will replacing the data-cable replace the broken-off piece?
If not, then for about $30, you can buy a new "empty" external case, and then "transplant" your current disk-space into the new case.
Take your current external drive to the computer-store, so that the new case that you buy will be the correct case for your existing disk-drive.
Of course, because you have a "small" (100GB) disk-drive, any warranty for the disk-drive probably has expired, and it would be good "preventative-maintenance" to buy a new external disk-drive, before your current disk-drive unexpectedly "quits" on you.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
How do I get the SW download for the USB-A Male to Mini USB-B Male Cable. Thank you
You don't need software for cables. You need drivers and software for devices, DVD/CD drives, ipods, mouse, external burners and hard drives etc. The cables are irrelevant and the computer doesn't recognize cables. I hope this helps and good luck.
Nov 18, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
The connector of my seagate free agent 160gb is broken, can i bypass the connection with an other adaptor in the internal hard drive
Solution No1:
You'll need to take it apart desolder existing cable and solder a new one (standart you can get in any sho).
Note: If you'll mix up wires than you can damage your motherboard or hard drive itself.
Solution No2:
Take it apart, remove hard drive, buy a new 2.5" SATA Caddy and fit you hard drive to it.
Mar 11, 2009 | Seagate FreeAgent Go 120GB External USB...
Pc hard drive
Yes, that correct you can just need to take the hard drive from your desktop and get a external hard drive ecnlosure where you need to put the hard drive and connect it to your laptop via USB cable, check this link for the sampole of the hard drive enclosure that you need to buy http://www.tigerdirect.com/applications/Category/category_tlc.asp?CatId=2777&name=Hard-Drive-Enclosure
Hope that helps.........
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Shuts off every 5 minutes after being turned on...
Well, I actually figured out what was wrong with mine.  It was actually my hard drive which was causing the reboot. It was still under warranty, so I had it replaced.
Sep 22, 2007 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Archos AV 500 Digital Media Player Logo
273 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
