We have the Pioneer XD-Z54T and the CD player does not seem to be recognising some of our discs. We have tried the discs on another player and they are fine. Could the problem be the laser?
  • da fish Feb 23, 2009
    WE have the very same thing happening to ours,don,t know where to go to get it sorted.any idea,s.declan in wexford irl.
SOURCE: Need programing guide and codes for a Jensen 6-device Universal Remote (Jer622)
I have this remote...only Pioneer listings are as follows: TV: 1004,1006,1089 VCR/DVR: 2010,2055,2071 DVD: 3312,3311,3287,3286 To program (for example TV setting): Press and hold down TV while entering code i.e. 1-0-0-4 To manually cycle through all codes (example for TV): Press and hold TV while pressing and holding ON/OFF, after 3 seconds the on/off button light should come on and stay on - release all buttons. Turn your TV on and press ON/OFF once each 5 seconds until your TV turns off. When it turns off, you have the correct code - press the stop button. Good luck.
Posted on Feb 18, 2007
SOURCE: used lens laser lens cleaner & now player won't play.
Hi Mollins, did you ever resolved your DVD player issues. I have the same problem and I dont know what to do.
Posted on Mar 14, 2007
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
SOURCE: CD player can't find the disc.
Hey man, I had the exact same problem with mine. What you do is take off the top cover which has 2 screws on top and 3 on back side of top. You'll see where the two parts come together to grab cd and spin it. Well, you should also see a little "eye" lens that actually reads the disc. Clean this off with windex or some time of cleaner. Bam, It works.
Posted on Nov 24, 2007
robotek
  • 1512 Answers
SOURCE: Pioneer PD-206 wont power up
Hi tfulton
Try disconnecting from the power and powering it up again to reset the unit.
If it still wont cooperate, the unit will have popped a IC protector in the power supply. Not an uncommon fault. The burnt disc you used may have pushed the tracking servos a little hard and a circuit protector has kicked it. Pop the lid off and look for a black 2 wire device about 4mm across that viewed from above has a D shape. Measure it with an ohm meter....It should read low ohms, if it does not... it has failed. It may be marked as ICPxx(from memory)
A fast fix we used for this is to grab the device and give it a 200 deg twist to short the legs together. Soemtimes(often) the body of the device will break off, just solder the legs left behind.
They have a habit of failingl with no reason, and shorting across them will not affect the operation of the unit, nor put it anything in jeopardy.
OR pull the board out... and replace the device, although I can tell you through experience, they may fail again.
Good luck, if you have any questions, just get back to
me here. :)
regards
Graeme
Posted on Mar 08, 2008
Pioneer PD M502 won't recognise Remote controller
this Pioneer PD-M502 have no remote sensor.mean this model was not designed to work by remote control.
Jul 01, 2012 | Audio Players & Recorders
CDX-FM65????? DOES IT EXSIST???
CLICK HERE for the specs on the CDX-FM653
No manual is available from pioneer for download.
ERROR 11 on pioneer cd players is common.
It can be due to a failing laser or dirty lens. It means that the CD was not recognised, either because of the CD scratched, or it could possibly mean the laser is out of alignment.
If the player works fine with other discs - chances are it needs a good cleaning.
If the player wont read any discs - it's time for a service call. Typically - I charge $50USD for clean and alignment.
you can do it yourself (clean it) by disassembling the player, and using a qtip and isopropyl alcohol - however an alignment requires a special alignment tool.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 16, 2009 | Pioneer CDX-FM657 6-Disc CD Changer
Kenwood dp-28 cd player jumping cd
My CD player starts to jump after a few minutes and also it doesn't recognise certain CD original disks
Mar 19, 2009 | Kenwood Audio Players & Recorders
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Pioneer XV-DV424 dvd player does not recognise bought dvds (region2) -we are in region 2. Recognises every other disc fomats eg DVD R, CVC, CD
Is the player a region 2? Just because you are in region 2 does not automatically make a player from another region change....accordianaman
Jul 20, 2008 | Pioneer Televison & Video
How do you get the receiver to palyback mp3s?
How to set the clock of pioneer DEH-2800M car radio?
Oct 09, 2007 | Pioneer DEH-2800MP CD Player
Aug 12, 2007 | Teac PD-H300 CD Player
846 people viewed this question
 Grubhead
Grubhead
