Question about Sony KP-57WS500 57" Rear Projection Television
The tv goes on stand by mode by itself. My 57' sony does not turn on but remains in stand by mode. Blinks 9x then stops, then starts all over again. What needs to be done?
  • 1 more comment
  • drealdeal Oct 05, 2008
    guess I would have to call a tv tech
  • Aktbird Oct 15, 2008
    My 57"Sony will not turn on from the power button or remote. The stand-by light flashes 9 times. I found that if I unplug it from the outlet and wait a few seconds then plug it in, I will hear small click in the rear, like a relay clicking, then it turns on and works good till it is turned off. It then has to be unplugged and plugged in to get it to start up again.
  • Anonymous Nov 08, 2008
    Mine does the same, but now it will not turn on after being unplugged. Any help?
  • 10,594 Answers
9 blink in your Sony KP-57WS500 shows error / problem in Audio section.
1= +19 volts &-19 volts are shorted by any reason on A and B board.
2= IC708 is faulty on A board
3= PS701 & PS702 (fuse) are open on A board.
Above are possible reasons of 9 blinks.
If you have electronics knowledge and have tv repair skills then check as per above info. otherwise I recommend get help of TV tech person or contact nearest Sony service center.
Thank you.
Posted on Oct 05, 2008
  • Shahid Electronics
    Shahid Electronics Oct 05, 2008
    Correct if you don't want to repair it yourself.
    How about rating this solution as all necessary info has been given to you?
    Thank you.
Kv xg25p50 57
It's a Sony TV I assumes. The reson for this fault to Sony TVs are many. After witch ON, if it goes to standby mode, indicates some fault to its main baord or power supply regulator section itself. Look for any blinks occurs, after to goes to standby mode. If yes, count the nuber of blinks occur at one time switch ON, These are called blinking codes, and fault indications. If you are somewhat sound in electronics, check this link after counting the number of blinks. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. The site has details about blinking codes to many models of Sony TVs. Check it.
Jul 04, 2013 | Televison & Video
Picture went out and red light on the stand by button blinks ten times and stops for sec and starts the ten blinks all over. When I turn TV on I can hear sound of the tv trying to turn on but no sound or...
10 blinks on KDP-57WS655 model no. is an error code for "High voltage protection". I can tell you exactly which part gone bad and assist you to fix it yourself. Click it here.
Jdvillanueva
Sep 29, 2011 | Sony Grand WEGA KDP-57WS655 57" Rear...
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
57 "SONY, DOES NOT TURN ON BUT STAND BY LIGHTS BLINKS 9X, THEN STARTS OVER
I dont think your unit has big problem.
1. 9X blinks means 9 VDC supply is shorted either in A or B board.
2. IC708 is faulty in A-board
3.PS701 or PS702 is opened in A-board.
Dont forget to Rate!
Good Luck
Dals123
Oct 21, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony projecting tv kp-57wv700
Based on service manual info, it cant blinks 7 times as per symptoms, please count again blinks. It can be 5 times.
If its 7 times blink, Horizontal Deflection stopped in this case. If you want to repair it at your own, please let me know to guide you further but it is necessary you should have knowledge of electronics.
Aug 18, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-57WS520 57
The 9 blinks on your TV means:
+/- 19V line is shorted
IC708 could be defective
PS701 or PS702 is opened.
To do this repair you will need to have basic electronics knowledge that includes hand soldering, use of a DVM and be very careful when working around high voltage.
Aug 14, 2008 | Sony KP-57WS520 57" Rear Projection...
KP-57WS500
I had this problem and at the same time I was getting blue tint. When the blue got darker, this would happen, Adjusted the voltage on the guns (3 screws in the front - lower panel off) and the blue went away and it stopped turning off. But later, it would start all over again. Same procedure, same fix.
Jun 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Won't turn on.
My Sony KDP is blinking 6 times. My guess is the blinking is a troubleshooting code. We just need to located the chart to describe the blinks.
Sep 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KP-57WS500 57" Rear Projection Television Logo
149 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
