Question about Brother MFC-465CN InkJet Printer
Paper Jam I have remove the paper according to instructions, but I keep receiving the paper jam screen
  • 3 more comments
  • sbanks395 Oct 05, 2008
    I just need some help. Please help?
  • rjseaman01 Feb 21, 2009
    I keep getting a paperjam message but there is no paper in the machine.
  • Marcia Mariacher
    Marcia Mariacher Apr 05, 2009
    I had a very bad paper jam with ripped paper involved. I've gotten all the paper the eye can see and fingers can reach out (top, front, and back openings) but I am still getting the "paper jam" notice. I've disconnected and reconnected, closed all the doors, all to no avail. All the manual says is to remove the printer head. I don't want to do that for fear of damaging it, and the manual doesn't direct how to anyway. I have a Brother MFC-465-CN. Thanks in advance--
  • jldehnel Apr 10, 2009
    +For months now I have had the same or similar problems with my printer. Repeated attempts to clear paper path, opening and closing doors, etc. would usually result in resuming print operations. However, this has become more frequent and is accompanied with gear stripping noises. I have looked through the machine as best I can to detect any paper or foreign matter with no luck. Finally, tonight the machine is simply not even recovering. I unplugged the machine and plugged it back in and all it does not is show "Please Wait". If I press the off switch it will respond with some gear or head movement noises then stops again without further action.
  • dbagal May 07, 2009
    I can see paper stuck in the printer but can't get it out from the lift up lid or from the back. I dont know what the ACF lid is but assume it is the one with the blue support. I cant find any black switch. Please help.
  • 320 Answers
Open the back door and check if the paper sensor was pushed out of position
Posted on Jan 13, 2009
  • STEVE RAYMOND Jan 19, 2009
    let me know where the jam is and i will see if i can help! brother tech
I have he same machine. I found the solution elsewhere on this site for another Brother Copier.
Lift the ADF lid locate the little black plastic 'switch', slightly recessed in the fourth slot from the back of the printer, gently tap this swith so it moves, I tried forwards then back, close lid, press Stop/Exit.
Ding Dong! - Works a treat.
Posted on Oct 14, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ... Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ... Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ... There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ... > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
We have a sp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
Dec 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
202.01 and 202.03 Paper Jam
The 202.03 error code has to do with an early life failure of the fuser. Try replacing the fuser. If that doesn't work, a tech is needed to replace rear door. Don't forget to reset maintenance counts when you replace fuser!!
Jul 01, 2009 | Dell 5310n Laser Printer
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
According to the manual, the paper may be inside the right side door, or in the paper tray.
If you have the manual, its on page 6-2.
If you don't have the manual, it's here:
Jan 18, 2008 | Canon imageCLASS D760 All-In-One Laser...
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-465CN InkJet Printer Logo
452 people viewed this question
James Cagle
James Cagle
Jim Keysor
