Question about Watches
Relic Watch ZR15478 trying to set watch
How do I set this watch with the day, date & time dials
5 Suggested Answers
SOURCE: Setting watch date, day, etc.
yes. i do this problem
Posted on Nov 04, 2008
  • 2692 Answers
SOURCE: Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Posted on Dec 21, 2008
  • 3 Answers
SOURCE: adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Posted on Jul 05, 2009
OhioTrucker
  • 33 Answers
SOURCE: there is a spinning dial around my relic zr15478
Its a timer if its working, not all do, some are decoration
Posted on Feb 27, 2010
SOURCE: setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Posted on Sep 28, 2010
How to set the time and day and date on a relic zr15701
Pull the crown out once to set the date. Pull it out a second time to change the time. Of course move the crown up or down and see if it will change.
Dec 24, 2013 | Relic Degrade Pocket Watch
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
Relic watch zr15478 adjust wristband
I'm having the same problem with this watch, I found this guide but it's for a similar watch and doesn't seem to help. I'm hoping this helps you more than it helped me
Oct 22, 2011 | Relic 0504648FA
Set the date on my new Relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Mar 22, 2010 | Relic watch
I need a relic gunmetal band for ZR15478, does anyone know from where I can purchase one online? pls help :)
I believe this is an item which is not only hard to find online but must match your watch precisely so I would not recommend buying it online.
The following link lists a company that appears to know a lot about Relilc Watches and there is a phone number you can call to assist you in finding the right band
Link @ http://www.amazon.com/gp/help/seller/faq.html?ie=UTF8&marketplaceID=ATVPDKIKX0DER&isCBA=&asin=&seller=AI4LSKP23K9DV&isPopup=
jackiaria
Feb 27, 2009 | Relic 0504648FA
Dec 21, 2008 | Watches
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Sep 03, 2008 | Watches
Relic watch 3 dial
Chances are they represent one of the following-
Month of the Year
Time of Day (military time)
Day of the Week
Day of the Month
It depends on what the dials have on them - usually there is some indicator (abbreviated months, numerical values, etc)
Feb 20, 2008 | Relic 0504648FA
Relic digital watch
Hold down the reset button until the hour digit starts to flash then to change the hour press the start/stop button then to change the minute press the mode button and keep pressing start/stop button until you get to your desired minute and just continue those steps through the date.
Oct 12, 2007 | Watches
Watches Logo
270 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
