Question about Kenmore 62602 Electric Dryer
Kenmore Dryer 80 series will not turn on.
I have a model number 66822692 Kenmore dryer that has just stopped turning on. There is power to the dryer, as I see the light inside on and when I turn the dryer dial it sounds like it usually does. However, the START button, when pushed each time does not start the dryer. I unplugged and replugged the dryer, and this did nothing.
Any help would be appreciated, my clothes are piling up. :)
  • 2 more comments
  • gobeavers Oct 05, 2008
    When I press and hold the start button I hear a slight whirring sound coming from the dryer.
  • deerhunter5 Oct 23, 2008
    Where to you find the switch?
  • cofarmer Nov 27, 2008
    Similar problem, though with a twist. Sometimes the dryer will start and run for about 15 seconds then shut off. I can hold start button in and it will run for 20 or 30 seconds then shut down. Won't start again until it sits for a while. When it first runs there is a squeal that seems to come from motor area but then goes away moments before dryer quits.
  • Anonymous Mar 15, 2014
    what is the depth of the kenmore 80 series dryer 66822692
  • 943 Answers
HI thanks for your question. theres a belt break switch on the dryer so that if the belt breaks it wont allow the dryer to start. check that. thanks the appliance doc. please rate my answer .thanks
Posted on Oct 09, 2008
Testimonial: "excellent, that did the trick"
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
My dryer wont work. my kenmore elite wont turn on. the light in the dryer is working so I know there is power to the unit but the control panel wont turn on. The model number is 110 60092991
Kenmore by Sears,
DD
This is really a simple project
I believe your belt broke and Kenmore put a kill switch to protect your motor and heating element.
there are two screws when you remove your lint screen.
Remove those screws.(philips)
With a straight screwdriver, gently pry up the top of dryer.
When loose, open all the way to the back and rest on the wall,
On each inside,behind the door, at the top, is a 1/4" bolt. Use Socket to Remove both. Pull up and out on the front and put it to the side.
Remove the drum.
Now you can clean the inside with a vacumn. See the kill switch in front of motor.
The model is inside the door on the left
since you have it apart check the drum rollers for flat spots as well as freedom in movement DO NOT GREASE
Put it back together
Jul 24, 2010 | Kenmore 63942 Dryer
Where is my belt on my kenmore dryer model #66822692 series 80
The belt goes around the drum 1b15519.jpgThe part number being 341241 on the common Kenmore dryer.
409d816.jpg110ef8a.jpg899f2ef.jpg19a8834.gifoil them rollers and idler. Old school training manual
MORE
Jun 29, 2010 | Kenmore Dryers
I have a Kenmore 80 Series dryer. When I push the start button it makes a noise but won't turn on or it turns on for a few seconds and then stops
Did you figure out what the problem was? I have the same problem with my Kenmore dryer.
Thanks
May 17, 2010 | Dryers
My Sears Kenmore 80 dryer will not turn on.
your dryer motor is worn out,replace it,the model number is inside the dryer door-mike
Feb 21, 2010 | Kenmore Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
I have a kenmore 80 series dryer that heats up and will not tumble. The model # is 66822692. Can you please help?
Open the back panel to access the belt. There is a motor to make the drum tumble by the belt. If the belt is not intact then motor turns but not the drum. If the belt is in good place then motor is not working. Check out the continuity of the motor, if there is then there is a problem with the circuitry. If there is not continuity from the motor terminals then the motor is burnt.
Dec 28, 2009 | Dryers
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
Kenmore 62602 Electric Dryer Logo
420 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
