Question about Microsoft Windows XP Professional for PC
Repeatedly restarts after Windows loads
I have a new to me/used computer that I know works, because before this issue everything was fine. When i put in the Windows XP download cd, halfway through i get an error message, so i figured that i'll take the HD out of my other computer which i use every day & just use the other HD as a slave for music, pictures, etc.
When i hook the new to me HD up as a slave, everything's fine on my current computer. But when I hook up my current HD with Windows XP on it, i get the "Safe Mode / Last Known Good Configuration / Start Windows Normally.. etc" screen.
When I click ANY of these, it gives me the little white windows loading bar & then restarts back to that same screen. I know that neither of the HDs or the RAM is corrupt & I'm completely at a loss.
Help?
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you tried, in addition to putting your second HD on the secondary connector, setting both HDs to Cable Select? This is how the South Bridge chip on newer machines expects them to be jumped.
    So you know, when you start an install of W2K or XP/Vista, the installation program creates a temporary folder for storage of the software. This is normally on the root HD of your system C: and looks like this $????$ where the question marks are specifc to your install but always preceded by a dollar sign and followed by a dollar sign. There is also temp files in the root directory of the primary hard drive that instructs the installer to pick up where it left off. By adding a second hard drive you have confused the installer and it gives up, starts again and then repeats like Ground Hog Day.
    If you can find a copy of Hiren's Boot CD to use, boot off that in your CD Tray and then navigate around the menus to get familiar with the programs located on this CD. As techs we all carry this tool with us, but you may find one to borrow for your needs. What you want to do is access the File Managers on Hiren's and use one that supports NTFS. Then you can access the files on your Primary Drive, delete all the temp folders and files and then try again. This is what I have to resort to when a PC shows up because a user has ended up in the same boat as you.
    Feel free to follow up by using the comment box below.
NEED HELP SETTING UP WINDOWS XP . MY WINDOWS IS NOT LETTING MY ICONS UP ITS SAY ACTAVITE WINDOWS
Posted on Oct 18, 2008
Locked up on restart... How do I solve this mess????
Sony's Vaio line of laptop and desktop computers ship with the latest version of Windows installed. Even the best designed Vaio computer can sometimes malfunction, occasionally in connection with an error in Windows. Boot your Vaio computer in Windows' "Safe Mode" to disable potential problem-causing drivers and programs to help you troubleshoot and fix your Sony computer.
Windows XP Press the power button on the Sony Vaio computer, typically found in the top right corner of the laptop's keyboard panel or on the desktop's tower. If your computer is already on, press "Start" in the lower left corner of Windows XP and press "Turn off computer." A new window will appear. Press the green "Restart" icon. Hold down the F8 key on your Sony Vaio's keyboard as soon as your computer's screen goes dark. A new window, labeled "Windows Advanced Options," will appear. Choose one of the Safe Mode options listed. "Safe Mode" loads the minimal amount of drivers, while "Safe Mode with Networking" also loads your networking preferences. Press "OK." b> Windows 7 Press the Sony Vaio computer's power button if it's off, or restart the computer. Click "Start" in the lower left corner of Windows 7 and choose "Shut Down." A new window will appear. Push "Restart." Press and hold your computer's F8 key. A menu called "Advanced Boot Options" will launch on the screen once the restarting process is complete. Choose "Safe Mode" or "Safe Mode with Networking" and press "OK."
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 15, 2013 | Computers & Internet
Windows xp will not load on MS-N011
Step 1:
Des Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Feb 05, 2013 | Computers & Internet
After Installing Windows Xp from Sata Cdrom everything works fine but when i Removed The Cdrom The Windows Won`t Boot Please Any solutions I diabled Sata from Bios All the same Eveythibg works fine when i...
did you remove all power and sata connections restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
Apr 09, 2012 | MSI Computers & Internet
I have a 320 gb hdd i don't know if it works properly or if it is fine but my laptop won't load up
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
hope this helps you
Feb 17, 2012 | Samsung Computers & Internet
0x000000D1 (0x00000014, 0x00000002, 0x00000000, 0xB712A875
It certainly does sound like a driver. I would just go on a driver update quest myself. Head over to nvidia and get the lastest Unified platform (nforce) driver at http://www.nvidia.com/content/drivers/drivers.asp if you are using a nvidia sound card.
Try restarting the computer on safe mode with networking ( You can goto safe mode with networking by - restart your computer and start pressing the F8 button repeatedly till you get the new boot options menu) and then restore the computer to an earlier date to which the computer was working fine.
I have had the similar kind of issue and was not aware what to do. While searching the web, I got the info about TheBestPcDoctor and I contacted their support. My issue is fixed and the computer is running fine now. If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Sep 07, 2011 | Microsoft Windows Vista Ultimate Edition
After loading the laptop, the screen goes black showing only a white mouse cursor that you are able to move. Even tried loading in safe modes but the page still doesn't load.
Please restart the computer in safe mode and check if that is loading. If safe mode loads well, then run system restore (Steps depend on the windows version you have) and restore your computer to a earlier date (say 1 or 2 days earlier) when you know that your computer was working fine.
If you cannot login to safe mode then we might have to do a manual registry restore
Please use the link to know more about it. If you are going to use the step, please keep a printout handy of the instructions.
For XP:
http://support.microsoft.com/kb/307545
(follow the manual steps)
For Vista & Windows 7
Boot from OS DVD and run startup repair.
Feb 03, 2011 | Computers & Internet
Driver issues?
Try the second hard drive in the first computer that's working. If it works all right then you probably have a RAM/MB problem.
May 27, 2009 | Computers & Internet
Windows Failed to load because Kernel file is missing
try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
May 17, 2009 | Dell Inspiron 1521 Notebook
Using with laptop
If you have the software installed remove it[ Start/Control Panel]Add remove software]
Let Windows do the work.
Sep 06, 2006 | Fuji FinePix 2650 Digital Camera
Microsoft Windows XP Professional for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
