Question about Whirlpool LGR7646E Dryer
Whirlpool dryer: supreme Not heating up
I have a whirlpool dryer that is not drying clothes. It seems not to heat up and the timer does not move from it's original setting. I have check the vents and all is clear. Because of the timer the dryer will not shut off automatically and will run until I shut if off manually.
  • 2 more comments
  • fraser3b1g Oct 05, 2008
    I have a whirlpool gas dryer lgr7646eq3 that will not heat up to dry clothes. It never gets hot and the timer when set does not move from it's original position and will not shut off automatically , only manually.
  • johnsontk47 Nov 13, 2008
    I have a whirlpool dryer and the heating element went. I've replaced belts before. I just want to know if it's difficult to fix my myself and what to look for when I open the back up. Teresa
  • Anonymous Dec 04, 2008
    Gas dryer starts to heat up and then shuts off.
  • joeyhaidusek Apr 03, 2009
    I have a whrilpool gas dryer that runs fine but only heat at times and the timer will not shut it off some times.
  • 943 Answers
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
Posted on Oct 06, 2008
I had the same problem I change the gas valve coils and it seamed to be working fine.
Posted on Jan 07, 2009
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Timer will run dryer but does not time
if the dryer has no heat the timer will not move on auto,when the heat shuts off the timer moves,when the heat comes on the timer stops,it will do this until clothes are dry
Oct 08, 2010 | Kenmore Dryers
Our dryer is not drying as it has in the past. Have checked the vent, drum rotation and heat, but still does not dry clothes properly. Any suggestions?
If the vent and the heat are fine then the only other thing that could be going bad is the timer motor. The timer motor tells the dryer how long to heat the clothes.
Apr 06, 2010 | Whirlpool LEW0050P Electric Dryer
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
My dryer is heating up but isn't drying the clothes
I would be REALLY suspicious of the exhaust vent. If the dryer is heating up and the drum is turning, it has to dry the clothes UNLESS there is no air going through the dryer. Disconnect the air outlet flexible plastic duct at the back of the unit, and turn it on. If there is no or very little air coming out, the inside of the unit will be plugged with lint. If there is lots of air coming out, the exhaust duct or the outside flapper will be plugged. Sometimes if the exhaust is routed through a cold space there will be so much condensation in the duct that it will droop and literally fill up with water.
Sep 09, 2009 | Whirlpool Dryers
Gas dryer does not provide heat or air
If you don't have heat the timer will not advance in auto dry. The first thing to check is the glow bar ignitor part number 279311.
Mar 30, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer is working but not heating up
check for power at the wall it should be 240 volts. if that is OK then you need to get a heating element. the towel setting is an automatic cucle if the cloths are not drying then it wont advance the cycle
Dec 10, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Dryers Logo
1,068 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
