Question about Hitachi 50UX58B 50" Rear Projection Television
Jumpy picture i have a rear projection Hitachi 50" I think. It is not HD. The picture jumps or shakes or something...just bounces up and down before it gets warmed up. Happens with cable or games or movies. I moved it from my mom's house and maybe it got banged around. Can you help me, please?
    Problem Solver:
  • 5 Answers
Ck for dry solder joints if you take rear cover off and just lightly tap on convergence ic heat sink if the tv jumps then you have to remove the board and resolder the joints. also if you have a magnifying glass ck all solder joints on board when it is out
Posted on Nov 02, 2008
Sounds like the convergence board, try replacing the STK voltage regulators and any resistors that may burned or discolored. This problem is causing the power supply to shut down probably.
Mar 13, 2010 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 50ex20b shuts of
Hi, you need to stop running the set , call a tech and have him do some solder re-work, this is a cheap, easy fix, keep running it that way and it will become an expensive fix, gl, video-tek
Jun 06, 2009 | Hitachi 50EX20B 50" Rear Projection...
Hitachi 50UX57B 50in Rear Projection Television picture not align
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Hitachi 50UX57B 50" Rear Projection...
Screen gets horizontal lines and jumpy screen.
Your problem is capacitors CP204 and CP205 by the 9 volt regulator on the main board. Cp204 is a 47 microfard @ 50 volt and the other is 100 microfard@ 16 volts
Nov 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Lamp flickering
Well jumping has nothing to do with lamp so called bulb.
You have what I would call a cold solder joint.
You're going to have to open the set and tap gently to see were it is comming from. If you know anything about soldering they you will know it is not that easy.
Once you think you have found the place were it seam's to be the place were it make's it jump more often, start again to make shure that's the spot and not the hole area.
Then remove the board and resolder,
Good luck
What About Bob
Timmins, ontario
Home of Shania Twain.
Mar 15, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Picture jumps or shakes
possible solder connection breaking down when the set is cold.look in and around the horizontal and vertical section for cold solder connections.
Nov 10, 2007 | Hitachi 50UX58B 50" Rear Projection...
Surround Sound Installation
The Hitachi 50UX57B is a 50 inch standard projection TV with a standard screen. It is not HD ready. If you need it, I think I can download the owner's manual (in PDF format) from Hitachi and foward it to you.
Aug 03, 2007 | Hitachi 50UX57B 50" Rear Projection...
Jumpy Picture on Hitachi 55FX48B
On older Hitachis the most common jumpy picture is loose connections on the vertical output IC. If you can tap on the main board and get it to act up then this is most likely the situation. I believe the location is IC401 and is located toward the front of the set on the signal panel. Not too tough to repair if thats all it is.
Jan 29, 2007 | Hitachi 55FX48B 55" Rear Projection...
Televison & Video Logo
179 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
