Question about Sharp FO 6700 Plain Paper Laser Fax
Fax machine seems to work as wll as copier, but a blinking red light keeps blinking and it points to the paper tray and say No paper (tray). I am also missing the top exit paper tray. the back of the machine seems to be making loud noise. how can i fix it all, the blinking red light to shut off, find a top tray for exiting paper and the motor to settle down, is there a configuration that can tell me if anything is wrong with it?
  • 48 Answers
No there is no configuration page. The red blinking light means you have no paper under your blue tray or the paper empty sensor is broke. To identify the noise open the lid then close it, if you hear the noise while the fax is warming up then most likely you have a bad gear that meshes with the fuser drive gear, although it could also be the toner or drum. If it's not the toner or drum I stongly recommend a service technician , he should be able to provide an exit tray.
Posted on May 25, 2009
Is the sharp FO04450 a thermal (roll paper type)
No it is a plain paper laser fax that uses a fine powder to print, called the "toner"
Jan 26, 2012 | Sharp FO 4450 Laser Fax
Sharp FO-3150 polygon error
You have a bad laser unit that can't be replaced.
Jan 16, 2010 | Sharp FO 2950M Plain Paper Laser Fax
I need to change the company's name on the printout page when someone receives it.
The 6600 opeations are very similar to the 6700. Go to the Sharp site at
http://www.sharpusa.com/products/TypeManuals/0,1083,23,00.html
download the FO-6700 manual, follow the instructions for setting the sender name and phone number beginning on page 29 of the manual.
Please make sure to rate this solution.
May 15, 2009 | Sharp FO 6600 Plain Paper Laser Fax
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Message that tray is out of paper, and tray is not in machine.(SHARP FO-5700 Fax)
Go underneath the machine and make sure that a black piece of plastic is secured in there. Sometimes they get pulled out when the tray gets removed.
Jul 01, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Sharp fax machine
I keep getting a "Line Error" canot send or receive a fax. I have a SHARP UXB700
May 12, 2008 | Sharp FO 3150 Plain Paper Laser Fax
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Sharp FO 6700 Plain Paper Laser Fax Logo
151 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
