Question about Xerox Phaser 8200DP Thermal Printer
Reset counter on Xerox Phaser 8200
I am trying to reset the maintenance kit counter for the Xerox Phaser 8200. I didn't use the machine for almost (or maybe more than) a year because it made such a racket when it printed. I finally fixed the noise problem but now the machine is saying I need a new maintenance kit. The kit is practically brand new but because I haven't use the machine, I think it is counting days not uses for this kit. I'm sure there is a way to reset the counter but I can't figure it out. Any help would be appreciated.
Thanks,
Grace
  • 1 more comment
  • E250k Oct 14, 2008
    Same here!
  • GraceMT Nov 29, 2008
    Hi Ken0297:
    Thanks for your response. Yes, I do remember you have to reset something but I can't seem to find instructions on HOW to reset the counter.
    Thanks,
    Grace
  • GraceMT Nov 30, 2008
    Thanks.
    I did this one other time without a external piece of hardware. It was some combination of buttons and atart up - but I can't remember what they were and cannot locate my notes. But thanks again.
    Grace
  • 4 Answers
You can buy a kit to refurbish your reset counter for $20.00 including shipping at http://skyforms.netfirms.com/cgi-bin/phaser.cgi . It adds 45,000 copies to the counter. Also, a guy on ebay sells the kit already reset for 32.95 plus shipping.
Posted on May 13, 2010
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Posted on Nov 27, 2008
  • ken0297 Nov 30, 2008
    This sounds like the supplies "Override" feature that HP printers have, I did this to my HP 2600n, it works pretty good to get the last 500 pages of toner out of your cartridge that would otherwise be thrown away.
The "counter" is an electronic module that is replaced when you replace the maintenance kit, this module measures "usage" but may also hold time & date info (possibly set from the printers internal clock).... I hear it is possible to reset this module but you will need a piece of equipment (chip resetter) that most of us don't have, I think someone on eBay is offering reset chips for $37 shipped.
Posted on Nov 30, 2008
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
How do I Reset the Maintenance Kit Life count on a Xerox Phaser 6360
Your just not meant to.
Fit genuine Xerox parts and have no further problems.
Good Luck.
Jul 17, 2014 | Xerox Phaser 6360DN Printer
Xerox 8560 Maintenance Kit remaining life
You're probably lucky that your machine still works after using non-xerox products, in any event, I'd suggest a new Xerox Extended kit, it's possible the non-xerox product didn't work as intended and your replacement kit wore out faster because of it.
The kit contains a micro chip which "resets' the counter in your machine, as the count comes from the kit, not the machine itself, however, the machine is capable of sensing when the maintenance kit has reached end of life regardless of count.
Additionally, you should check the wiper blade (you can see it when you remove the maintenance kit) for excessive wax buildup which generally means the machine needs service.
These are great printers, very fast for the quality. They can be quite a nightmare to service due to so many systems which have to be exact!
My #1 advice on this product is if you own one, never ever move it while it's hot! or you could face a very expensive repair!
Mar 27, 2014 | Xerox Phaser 8560N Laser Printer
Xerox 8860mfp how do I reset the Maintenance kit counter until a new one arrives
It cannot be reset at all.
Xerox makes you buy a new one, either 108R00675 or 108R00676
Whit
Item, Inc.
Dec 14, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Jun 03, 2009 | Xerox Phaser 8560MFP Laser Printer
The maint kit resets the counter when it is installed. You may have gotten a bad maint kit or the black plasstic part that the roller slides into is bad. That is where the connection is to reset the counter.
Harry
Mar 18, 2009 | Xerox Phaser 8560MFP Laser Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
Oct 13, 2008 | Xerox Phaser 4500 Printer
Phaser 8200 will not start up
Are you getting any fault codes on the screes? A fairly long number..
Jul 29, 2008 | Xerox Phaser 8200 Laser Printer
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8200DP Thermal Printer Logo
1,888 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
