Question about Siemens Washing Machines
F18 Error - Siemens Washing Machines
  • Aviel
    Aviel Jul 15, 2016
    Did anyone found a fiber filter inside the pump cover?
The error is caused by a blockage in the pump you need to drain the washer using the black tube near the pump drain or by unscrewing the pump cover next to it on excel 8kg washer these are at bottom right of machine. when all water out remove pump cover that you loosened to get water out then check for blockages inside. the pump has a device inside that should move round freely remove all debris replace and try to drain using drain cycle this will finish and hey presto back to normal!!
Posted on Mar 20, 2009
  • 2 more comments
  • harbindrakhi Dec 07, 2010
    Hi
    I've got a Siemens S14.39 washing machine and I'm getting the F:18 error message displayed when trying to wash clothes.
    I've checked in the manual and done what it says and also as someone has stated on the forum, I have cleaned out the pump.
    There wasn't actually any blockage in the pump and I've removed all the water and tried this many times.
    However each time it comes to the last minute of the wash (the empty function) it stay on this for a while then displays the F:18 error again!
    Any ideas to what the problem could be as cleaning the pump doesn't seem to work?
  • NicalsH Feb 06, 2011
    I had the exact same problem. The blockage was not in the pump in my case either. Instead the blockage was where the hose were the waist water goes out (the hose that comes out from the back side of the machine and goes to the floor drain) is connected to the pipe coming from the sink. That pipe goes then to the floor drain.
    So I suggest the following - make sure that the hose (and if the hose is connected to a pipe) is clear all the way to the floor drain. That solved my problem!
    /Niclas, Sweden
    If you have this problem of a Siemens E14-46 and gets the code F:18 - then see my answer below to harbindrakhi below. The blockage might be in the hose that goes from the backside of the machine to the floor drain. /Niclas
  • ahtis Feb 13, 2011
    Same problem and the cause was a blocked drain hose. This time it only was blocked by water.. .. frozen water :) There is about -20C outside and the hose goes in front of a poorly insulated garage door... ...so, greetings from finland :)
Thanks for the help, tried all of the above but still had problems, the man who moved the washing machine and replumbed it in for us never cut of the end of the pipe where the waste pipe fits to it, so the problem was the waste water pipe.
Posted on Jun 10, 2011
Hi there, drain the machine at the bottom filter and check your drain pipe after doing so, i found a coin blocked my machine... same error and working like a bomb!!!
Posted on Jun 21, 2013
F18 ERROR ON WASHING MACHINE
have you CHECKED the filter is clean
leave feed back
Jan 09, 2014 | Washing Machines
F18 error code on Bosch Exxcel washer/dryer, and water pouring out the bottom - any ideas on how to fix? Filter is clean.
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Sep 13, 2017 | Bosch Logixx WFT 2806 Front Load...
This might help you with the pump its on a bosch Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2013 | Bosch Logixx WFT 2806 Front Load...
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Error message F18 what does that mean? i lost the manual... michael
F18 (usually!) means there's some issue with drainage. If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it - plastic, lint, loose change, etc.
Mar 05, 2011 | Washing Machines
What is error code F18 please?
F18 means the filter is blocked. Look around for a propeller shaped part - it should be able to spin freely. If not, remove the debris so that it is unblocked. Good luck!
Feb 28, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Mar 21, 2010 | Hotpoint Washing Machines
Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
Washing Machines Logo
20,923 people viewed this question
Top Siemens Washing Machines Experts
Marvin
Marvin
Mike
jimorris77
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
