Question about Microsoft Xbox 360 Console
2 flashing red lights
My xbox works for about 5 mins then just shuts down with 2 red lights on the left hand side
That red light setup means that the system is overheating. You should be able to leave it off and just go again, but if it keeps doing it consistently like you say, I have to ask: is the console or the power supply box on a carpet? I recommend leaving them on a hard surface to prevent insulating any heat. These parts are prone to overheat. If that doesn't help, I dunno. Ask Microsoft. Probably an internal issue with heat sinks or heat compound, I'd recon.
Posted on Oct 06, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1& follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Red ring instead of green ring
how many quadrants are there lit if there is three lights then u have the red ring of death (RROD)
if u have 4 i think it means ur AV cable in the xbox isin proberly i think check its connected poperly and if thats not the problem TRY THIS
What we NEED 2 do is OVERHEAT ur xbox to do this u will need something that will fit through the little holes in the back of the console were the fan blows air out we need to stop these stick something like q-tips in the holes then after aba 3 mins it should overheat and two light should indicate (on the left hand side ) it has overheated to turn it off yet wait 1 min let it cook then pull the power out the back and let it cool down 10 mins (dont put in fridge or freezer lol) the turn it on GREEN LIGHTS BACK on line if that didnt work u might need to do x-clamp fix tutorials on utube or if that doesnt work TRY the oven fix were u stick ur motherboard in the oven at 230 uk or 475 usa for 10 mins TOP SHELF on BAKIN TRAY put it FLAT GUD luk
Nov 26, 2010 | Microsoft Xbox 360 Console
My Xbox 360 just started turning itself off after about 4-8 mins.2 red lights come on ,on the left side while laying flat.
You are having an overheating problem. 2 red lights indicates that the console is overheated, and to preserve itself it will shut down. You may want to try and replace the thermal compound between the cpu/gpu, cleaning them off first, To do this you need to open the xbox and remove the x-clamps.
Oct 20, 2009 | Microsoft Xbox 360 Controller
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
What does 2 flashing lights mean on an xbox 360?
The two red flashing lights on the left side of the circle indicate the thermal limit has been reached. (over-heating) Check to see if the fan on the back of the unit is blowing air. There are external fans that can be added to keep the GPU. (Graphics Processing Unit) and CPU (Central Processing Unit) temp down. Keeping the temp down can prevent the dreaded RRD. (Red Ring of Death) Here is link as an example of a cooling fan.
Shop around and find one that you like. Remember, when it comes to these computer chips, cooler is safer.
Dec 31, 2008 | Microsoft Xbox 360 Console
2 red lights on the ring of light
Oct 28, 2008 | Microsoft Xbox 360 Elite Console
2 light flashing red lights once game is on for 5-10 min.
your xbox is overheating put it in an open area and let it cool overnight i might even suggest the nyko intercooler ex
Sep 26, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
66 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
