Question about Toshiba 27A45 27" TV
Require a TV converter box?
This TV has a "3 line digital comb filter". [I assumed it was "digital" when i bought it a few years ago.] Is it analog and will require a TV converter box?
  • hobo_stabbin Jan 11, 2009
    JVC MODEL av-27f475 DOES IT NEED A DIGITAL CONVERTER?
  • 73 Answers
That doesn't have to do with digital signal, just quality, if your tv shows the channels as 4.1 or 4-1 : example... then it IS digital!
Posted on May 23, 2009
I have a nine year old Sony KLV-30HR3 Wega LCD TV and I want to use it without a Freesat box. I assume I'll need an inside aerial (the house has no external aerial) and a digital converter. Anybody ha
it really depenfdon howfar away or how close to you the stations are . most indoor antenna are for in same town use up to maybe 20 miles then you have to put one outside home on a pipe or rooftop etc Most flat panels are not requiring the converter box
Dec 25, 2014 | Sony Televison & Video
I'm located in Toronto Ontario Canada, I don't use cable and Toronto has converted analog to digital. Purchased my Daenxy DN-19 LCD TV about 3-4 years ago. I am assuming that it is new enough that...
Hi colleenyts,
Your LCD doesn't have a digital tuner to decode the over the air digital channels. A cheaper alternative for now would be to get a digital to analog converter box.
Let me know if you required further assistance.
Sep 04, 2011 | Televison & Video
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
DOES THIS TV NEED A CONVERTER BOX?
If you scan your channels you will find out if it is digital. Say for instance you get channels 2-1, 16-3, 12-2, 12-3, then your TV is digital. Now if all your channels have no dashes and your channels come up 2, 12, 9, 16, and so on then you have an analog TV. Since this is a walmart brand there is not any online support that I can see. If you bought this a few years ago then again your tv is more than likely analog.
Apr 24, 2009 | Televison & Video
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
Is the tv that I have bought about 6 years ago ready for DTV?
6 year old tv probably not digital ready. The converter box will work if tv is on channel 3 and you use a UHF antenna. Most converter box connections have 75 ohm connectors, your tv may have the round connector to accept the input signal. If you have screw on terminals on the tv you will have to go to Home Depot or Lowes and get a matching transformer to go between the tv and the converter box. UHF antenna can be made out of a coat hanger. Just make a circle clean the paint off ends and attach. Or just buy a digital booster antenna at WalMart.
Jan 11, 2009 | Daewoo DTQ-27U4SC 27" TV
Is the Weather Channel TV/Lantern/VEC130B digital?
I have the same TV as in the picture and it is analog(didn't check model #). I know of no way to use a converter box on it short of hacking it apart. Although it can still pick up any low power analog channels that maybe in your area. I just bought a nice hand cranked paperweight just a few years ago. lol
Nov 11, 2008 | Weather Channel COMPACT TV/LANTERN/ EA...
Converter box
if you do not have cable, fios or directv you will need the converter box
Oct 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Toshiba 27A45 27" TV Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
