Question about Akai LCT3201AD 32 in. LCD Television
Fuzzy picture on my 42" akai lcd tv
For the past few weeks my tv is very fuzzy when turned on. After it warms up for awhile if you turn it off, then back on the picture clears enough to watch but is still fuzzy. The blue Akai screen that appears when you turn it on is perfectly clear and the picture is perfect when watching a DVD. The tv is not even 2 years old, but is out of warranty.
  • 1 more comment
  • sulleyw Nov 15, 2008
    I was having a similar problem, but now my akai screen is bright pink. The tv shows are only coming in somewhat normal if I have the contarst up to 90, except that there is still pink in the sky. This makes it very difficult to watch any tv, because the picture is going from bad to worse.
  • hammond1981 Feb 06, 2009
    Ya same thing here I turn the tv on after not being on for a long period of time and the picture if fine... about five minutes later the screen goes fuzzy, i have to leave the tv on for about 30 minutes and then shut it off and then turn it back on and then it still has little lines running through it ,except for on dvd mode, it seems fine
  • Anonymous Mar 27, 2014
    I have 2 TVs live in an RV trailer. The TV in the back works great. The TV in the front is fuzzy and no channel comes in. I have checked all in puts, plugs and turned it off and on.
Get rid of the pice of ****... mine did the same thing about 6 months after warranty
Posted on Feb 06, 2009
    Genius:
  • 1,148 Answers
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Posted on Oct 05, 2008
Picture gets fuzzy then screen goes black-still has sound
It can be the T-CON board is over heated and goes out, it can also be the main board, you should try cooling the T-CON board when the picture gose out with electronic freeze spray for electronics troubleshooting to see if the picture will come back, need to narrow down the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 18, 2010 | Akai LCT42Z6TA 42 in. LCD Television
(Please Help)Need to unplug my TV everytime to turn it on
you have a bad power supply, here is the part number
MLT169B
google it or try to get here :>
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=MLT169B
Fosg2000, Rate me Please
Mar 15, 2010 | Akai LCT4216 42 in. LCD Television
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
The picture is very fuzzy (pixelated) when you first turn power o
this problem occurs usually in the power supply change or check the power supply borad
Dec 18, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Tv gone black and white
try letting it run for a little while sometimes it just needs time to warm up after not being used for awhile. unfortuntly i am not completly sure but i will look up more information on this.
Jan 03, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV turns itself off after turning on. TV screen goes black.
Based on what I have read AKAI has reoccurring problems with power supply and bad DVD sound. The problem you have is caused by the DVD player trying to start. Never leave a disk in when you shut it off or you will have the same symptom you are describing.
Oct 07, 2008 | Akai LCT2721AD 27 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
803 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
