How do i connect arouter to my computers - Computers & Internet
  • 60 Answers
You would have to take the ethernet cable out from the back of your computer and plug it into the router into the port that is off to one side by itself. ( away from the other four ports ) then you have to connect a ethernet cable to each of your computers from each of the ports in the back of the router.If you have windows XP or Vista then your computers should be ready to go.
Posted on Oct 06, 2008
Sharp aqous on switch does not work
If it is the soft switch (optical) unplug the TV for 2-3 mins then plugin and retry. clean area arout the remote sensor on tv and remote with soft cloth.
Oct 20, 2011 | Sharp Televison & Video
I have arouter .i want fire wall and mac filter disabled. how can i do that
1.Firewalls setting are in Windows <System / Security > in the "control Panel" then go to
"Windows Firewall"> then > "Allow programs to programs to communicate through Windows Firewall"
Setting up an Allow Access List
1. Select the "Allow" radio button (a) to begin setting up a list
of computers allowed to connect to the wireless network.
2. Next, in the "MAC Address" field that is blank (c), type in the
MAC address of the wireless computer you want to be able
to access the wireless network, then click "<<Add" (d).
3. Continue to do this until all of the computers you want to add have
been entered.
4.
Click "Apply Changes" (e) to finish.
have to log into the router to change the MAC information. Should be 192.168.0.1 in the browser > this will bring you to the routers gui.
Apr 09, 2011 | Belkin F5D8236-4 Router
I cant install the wireless router please help me
Assuming you've got the disc for the router,install this first.Arouter has to have a driver programme to make it work.If your pc can't find the driver then you have to use the disc that comes with it.After you have installed the software driver,restart the computer.when your desktop comes up you should have an icon in the right bottom corner of your task bar.This is the icon for your router.The software should automatically drive the router to receiving the signals from your phone line.Look at the led lights on the front of your router,they should all be lit up barring maybe one of them.The internet connection l.e.d should be lit.
If it isn't,you've got to set up an internet connection on your computer,by going to : Control Panel,network connections,connect to internet.You should have your servers phone number as well,and the routers key code i.e. WPA 1245 or KEY LETTERS, DD10GC5DB1.THESE CODES HAVE TO BE TYPED IN THE ROUTERS CONFIGURATION BOX.If it gets really difficult for you get the server to work with you on the phone.It gets too complicated here online to explain everything.The instructions should come with the router,and if your pc hasn't a wireless driver you will need a wirless adapter to plug in your USB port and then configure this as well to receive the signal from your router.
Aug 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
1994 mercedes SL500 air conditioner will blow cold and work fine for a few weeks and then blows hot or NOT cold for 3-5 days & then will work again for no apparent reason. Is this a switch ?
Most likely low freon tripping the relay so as not to hurt the compressor. Ambient temp has alot to do with it. Low side should be pegged on the gage when reading with motor off. While running with full a/c at ilde should be arout 50 psi, at 2000 rpms should be at least35 psi. When outside temp drops it will turn the Klima relay off or when pressure drops while running it can shut off. If the pressures are correct the pressure switch on the drier could be bad.
Jul 28, 2010 | Mercedes-Benz SL-Class Cars & Trucks
My linksys is not working. all lights are on and they are not blinking like it should be. i want to reset without my cd. pls help
If you want to reset the router , then you will need to reconfigure the router.
Press the reset button on the back side of the router for at least 30 seconds. you will need a pen or a paper clip. Once you reset the router , unplug the power cable to the router and plug it back in. wait for 30 seconds.
Now you will need to reconfigure the router.
Click Here or more info about router set up.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Hyundai stereo
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Sep 20, 2009 | 1999 Hyundai Accent
LB2 with 1 computer 2 modems.
look wich modem is online and connect arouter to it with broadband before doing all this unplugged the modem and run ainternet cable called cat 5 from modem to router install cd after that restart pc and plugged modem and router back in outlet
Aug 05, 2009 | HotBrick SoHo LB-2 (LB2) Firewall
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
Can I share 1 printer with 2 computers 1 Vista 1 XP with the hub?
Yes you can share out one printer from 2 computers. you can either set up a home network using arouter to connect your 2 computers. Or you can use an a /b switch to share the printer.
Nov 21, 2008 | Belkin BLKF5U201 USB Peripheral...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
