Question about Refrigerators
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
  • Mr Barnard Oct 06, 2008
    Thanks , the condenser is free from any significant dust , it is mounted on the rear of the fridge (it is an upright model ) by frost I mean its developed ice in the freezer (which is almost empty) also the compressor is quite hot and the overflow bowl is dry . I cant see any removable grill .
  • 750 Answers
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Posted on Oct 05, 2008
  • Neil Golan
    Neil Golan Oct 06, 2008
    The grill only applies if the condenser is under the fridge. Not in your situation.
    If the compressor is to hot to touch that sounds like a bad cmpressor.
    huuum
Zanussi zrb324nwo fridge not chilling.freezer forming ice/frost
Sounds like a defrost component Dave Start by turning the defrost timer slowly clockwise until refrigerator stops running and then stop. Open freezer and look and feel. Is defrost beginning to melt the ice?
Fridge Freezer Timer
Genuine spare part for select models of Electrolux, Faure, Zanussi and Zoppas fridge freezers.
Defrost Thermostat
or the
Fridge Freezer Defrost Heater
If you have questions please let me know, Thanks John Tripp Appliance 911
Contact Me Here
Sep 22, 2014 | Refrigerators
Zanussi frost free fridge freezer we have had two zanussi fridge free freezers in the past month that do not drain away the water from the fridge. The water builds up under the vegetable drawers and...
this is a common fault with them, when packing them some of the packaging blocks the pipe. if you use a net curtain thing that hold up the net curtain push it down the hole up and down a few times then look at the drain away at the bottom of the fridge take the bits out. should be fine then. it happen alot and to deferent makes and models.
Sep 16, 2013 | Refrigerators
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Zanussi Refrigerators
Excess frost and condensation
Could be that it is not getting a good seal when the door is shut. Check for obstructions causing that and check the door seal to see if it needs to be replaced.
Mar 13, 2017 | Sanyo SR-9510W Refrigerator
Can i turn the freezer part of my fridge of so i can defrost the bottom part n leave the top part on , i have a zanussi electrolux
no your model is a single compressor which runs both frdge and freezer.. freezer is supposed to be frost free however freezing elements can be overwhelmed with frost if door has been left open. there is a drain hole behind the back panel of the freezer that can block or freeze up causing water to flow in tp the freezer and turn to ice. complete defrost and check that drain hole is clear to fix it.
Jul 24, 2010 | Zanussi ZEBF250W Bottom Freezer...
Zanussi frost free fridge freezer leaking water at back
Here is a link for your unit's manual: http://www.serviceforce.co.uk/pdfs/U30164.pdf
May 15, 2009 | Refrigerators
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Aug 14, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
LARGE WATER LEAK ON FLOOR
the reason is probably that the drain hole in the freezer (i assume this is a frost-free type) is blocked. take off the rear panel of the freezer and you will probably see a block of ice at the bottom. melt off with a hairdryer and free the drain with hot water making sure that water flows freely away
May 06, 2007 | Zanussi ZEBF250W Bottom Freezer...
if problem happens every fewhours it is possibly the defrost element
Mar 20, 2007 | Zanussi ZEBF277W Bottom Freezer...
Refrigerators Logo
590 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
