With good battery and ac adapter notebook will not turn on?
SOURCE: My Laptop does not turn on.
That orange light is usually an indication that the battery is not working properly. If you turn the computer on and take the battery out and put it back in it the yellow light might turn off. There is another indication that you have something in the power settings that might need to be set properly. Check in the control panel>power settings and see if the battery and power settings are okay. Also, sometimes the mute on the volume might be on. Lastly, I had a laptop that never turned on and when the hardrive was taken out and the power was turned on it still did nothing until it was turned off and the harddrive was put back in then turned on again.
SOURCE: asus dont turn on
try this
1st. turn off laptop
2nd. unplug power supply
3rd. remove battery
4th. let stand with out any power for about one min
5th. put battery back on
6th. place the power supply back in
7th. turn computer back on.
Should work!!!!!!!!!!!! Good Luck!
SOURCE: Asus w3j orange led battery light keeps flashing,
This seems to be a issue with the AC adapter. Its not driving enough power to the laptop and neither charging the laptops battery. Try using a different adapter.
If the problem still exists, Then its to do with the internal power supply setup inside the laptop and probably you need to rip the laptop apart and check the power chipset.
SOURCE: AC Adapter is beeping
the best would be ebay. type in your model number and you should find a compatible version. i dont recommend the universals, they dont show up on certain computers correctly such as dells. most charges retail on ebay for about 16 bucks. if you want it fast. get it overnighted. still will be cheaper than anything you buy in the store..
heres a link
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=acer+aspire+charger&_sacat=See-All-Categories
good luck!
ruben
SOURCE: Asus G73 won't Turn on. The power button gets no
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
