Question about Hitachi 42HDS69 42 in. Plasma Television
Hitachi 52 in. Plasma
The screen has been flickering for a few weeks now. Today, it finally went completely out. The screen is black, but we can hear the sound. We've had this tv for under two years! Please help!
  • 1 more comment
  • Anonymous Jan 28, 2009
    screen is flickering grey but sound is fine? please help
  • neddyb823 Jan 28, 2009
    model # 50hda39 screen is flickering grey but still has sound, please help
  • pauledwards Feb 27, 2009
    screen suffering flashing thin lines across it for intermittently for weeks , lately getting worse till screen goes black. sound still ok. only temp cure is to switch off for while then on again , screen lasts for hour or so then starts agin. luckily still under extended warrenty so tech coming to fix.
    Sergeant:
    Champion:
  • 223 Answers
I think you may have dry solder joints on the line output stage. If the solder joints are checked and found to be good then suspect a component on the line output stage or the line output transformer itself. If you can check these faults for yourself start with the solder joints otherwise find a competant technician. Hope this helps.
Posted on Oct 05, 2008
The screen on my Toshiba Tecra laptop has been flickering the past couple of weeks. Today, after using for about 5 minutes, the screen went completely black. I had to reboot to get the screen lit again. ...
Sounds like an inverter problem. If your laptop is still under warranty, send it in for repair. If not, and you know a little something about taking laptops apart, then you can take the screen a part and see the inverter behind the screen. It is long and skinny and has wires coming out of both ends, one side going to bulb, the other to the motherboard. Inverters are fairly cheap, and easy to replace... it's getting to it that is a pain.
Jan 03, 2011 | Computers & Internet
No Picture on a Hitachi 42EDT41A
Then it is probably not cold solder joints. You wouldn't think that an lcd TV would need a high voltage transformer but it does. They are very small compared to CRT televisions but they power up the screen. Without it you have no backround light to veiw what is there. There are two neon lamps on either side of the screen but they rarley go bad. My guess is the transformer ot the power supply feeding it.
Jul 25, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line on plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 19, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
My flat screen tv turns off after ten min
We had a Hitachi that did the same thing. If you got it from a dealer.....TAKE IT BACK! The problem will not go away. It is a lamp heat sensor that protects the projector from over heating. These are defective and they don't know what to do to fix them. They will have you change out the lamp, send to a repairman to replace the sensor and he will have to watch it for a week to see if that cures it.
We messed with this for 10 months, before they finally did a buy back and we went and bought a new Sony.
Jan 19, 2009 | Toshiba 32AF43 32" TV
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Black out?!?!?
I finally got information from the repair shop. Apparently it is the upper and lower panel drive. The parts are supposedly not more than a couple hundred dollars, though I'll let you know when I get the bill. I do want to say that Hitachi was great when I called them. Even though my plasma is out of warranty by a few months, they agreed to pay for parts if I pay for labor. That just might keep me buying Hitachi products despite the issues I've had with my 2 plasmas.
Jun 05, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Problem with RCA D52W20 HDTV rear projection television
Go to this site you need a flyback its the only onethey sell for an RCA number 259296 cost less than 50.00 and they provide free tech support so you can do the repair yourself which takes about a half hour. a repair shop will charge abut 400 to replace the flyback. heres the link
http://servicemanuals.vstore.ca/
Apr 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 55hds69
Loose connection..get a repairman to open it and secure the connections
Mar 07, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Picture flicker
You can get info at ctechnicians.com
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black screen 53in Hitachi 53UDX10B
At seven years old, thats a toss up, because most likely you will be nickle and diming the set from here on in. In my opinion, get a new set. Good Luck
Mar 30, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
203 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
