Problems with setting up wireless router wrt310n, wireless printer Dell 968W, Dell XPS laptop and Hughes net
Finally thought I had everything hooked up and working. Just a little while ago, could not print, ran back through set up. Then I lost connection on everything. Received a message "cannot communicate with Primary DNS Server, pinged host no reponse. Said to reset network adapter. Could not get anything to work... Had to hook back up straight to my Hughes net HN7000S to get back on line. Can you please let me know how to hook up everything (Hughes.net, WRT310N wireless router, Wireless Dell 986Q printer and still be able to use the laptop also) My desktop is a XPS 420. I would greatly appreciate it. I do not want to have to keep hooking and unhooking everything, or keep having to set it up etc, you know what I mean.
  • kseal3 Oct 05, 2008
    Yes it appears to be working fine at this time. If for some reason I have problems again, I know where to get my solutions.
    Thanks
  • 13,433 Answers
Try reseting the wireless router, theres a reset button hold it down for 30 seconds.
Posted on Oct 05, 2008
  • 1 more comment
  • Ekse Oct 05, 2008
    to hook up everything.. HEres how my network is set.
    Adsl -> switch -> wireless router.
    Connect your internet cable box / adsl directly to your wireless router, internet port, or place a hub or other device in the middle, if you need to. If not, just plug it directly to model / cable / adsl.
    So connect directly
    Hudges <-> Wireless
    But reset the wireless and reconfigure.
  • Ekse Oct 05, 2008
    Ok, I see.
    Connect the satellite modem to the wireless internet port. and reconfigure the wireless ones you have reset it. It should work fine.
    Let me know if you need any instructions, about the wireless or how to configure it again.
    Thanks,
    Ekse
  • Ekse Oct 05, 2008
    Make sure you enable security on the wireless, if left open, anyone could go in and change settings causing your network not to work. also the satellite connection might be unreliable at times.
Hi I Have A Dell 968w Printer It Will Not Hook Up To My Network
hey if your printer has a usb cable thats another way you can connect it to your computer just download for the printer and if u have an usb on the back of the printer and it will read everything thats how i connected mine and it works
Mar 17, 2011 | Dell 968w Printer
Dell 968w wireless printer
Go inside printer menu and assign it a static IP address, address that is not in use by any of your other devices. use 255.255.255.0 for subnet and your router ip as gateway
Jul 26, 2010 | Dell 968w Printer
Hughes net hn9000 I lose connection when I try accessing Inter.
Try to upgrade the firmware of the router.
After upgrading the firmware, reset the router and reconfigure the router.
Click Here for more info
Dec 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Dell 968w printer - won't connect to my Mac. is there a driver I can download to fix the problem? Dell tech support states this printer won't support a Mac OS.
For basic printing, use the PC as a server:
http://iharder.sourceforge.net/curre...winmacprinter/
I don't have personal experience, but I'm guessing that for photo printing you'll need a new printer.
Oct 13, 2009 | Dell 968w Printer
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
Apr 30, 2009 | Blitzz Technology (BWA611) Router
Wireless router
The problem is the Linksys wireless router is not properly configured. Try downloading the automatic configuration file which can be accessed from the Linksys site for your specific model wireless router.
Hope this helps you.
Dec 21, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless network problem
What operating system do you have running on the Dell? Is there a hardware/software firewall setup/installed?
Nov 25, 2007 | Dell Inspiron XPS M140 Notebook
Computers & Internet Logo
1,139 people viewed this question
David Payne
David Payne
