Question about Toshiba Satellite A100-S8111TD Notebook
Screen colors inverted
I all the colors on my monitor have been inverted! it was fine last night but when i opened it this morning all the colors were inverted, i tried restarting and everything but i cannot fix the issue? what do you think could have happened or is there anything i can do to fix it?
  • Anonymous Mar 17, 2014
    My aoc 2036s monitor is connected to my Asus laptop. The colors on the monitor are inverted. How do I fix this problem?
  • Toshiba Master
  • 5,568 Answers
If you or a friend can acquire an external monitor for a short while, you will be able to at least separate the problem into two areas; if the test monitor shows normal colors, then the display section of your laptop has failed. If the external monitor shows the same color problem, then the video processor has failed.
With this knowledge, you can start making calls or emailing to determine what the repair cost would be.
Since the video processor is probably a part of the motherboard, this might entail a motherboard replacement since replacing chips by hand that were installed by robots may not be practicable. If it is a display driver failure, the entire display might have to be replaced for the same reason as mentioned.
In my mind, the display replacement might be a tad less expensive but not by much.
There is a slim possibility that the driver software has gotten corrupted so if swapping displays still doesn't conclusively tell you where the problem is, you might try removing the driver from the Device Manager and rebooting. Win should 'find' a 'new device' and reinstall the driver.
Posted on Oct 05, 2008
My Samsung SyncMaster 931BW monitor has been working fine for me. It was working fine last night turn it back on this morning and the screen is just black. Reset computer checked the cords and power outlet...
Try it with another PC to make sure is is not the PC video card problem, also chek the cable. If it still does not work, then you will have to open it up.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 05, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
We turned off the monitor last night and now it wont come back on this morning, The little light is flashing but screen does not come on
What is the make and model, age of the monitor?
The problem can be bad caps in the power supply, bad backlight inverter circuits, or bad lamps. http://s807.photobucket.com/home/budm/allalbums
Feb 26, 2010 | Computers & Internet
My view sonic monitor gat very dark. can still see but very dark. do I need a new monitor ? was fine last night and this morning had problem. I didn't shut down over night.
It sounds as though either the backlights or the inverter(which supplies power to the backlights) has gone. If you can still see the desktop but only if you look closely and it is very dark, then the monitor will need repairing or replacing. If it is the invertor it can be done at a resonable cost - if it is the backlight it would probably not be worth repairing. Also it will cost just for an engineer to check it out.
Nov 16, 2009 | Computers & Internet
Tv repair
I soudcs like the backlight inverter board is bad or the power supply is npt supplying 24vdc to the inverter board.
Oct 31, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
My 32" Astar LCD TV will not power on. It was fine last night, then I wake up this morning and it will not come on. I t is only 2 yrs old
Thankyou,
Bonjouir honored Sir/Madamme, call me V. Unfortunatley this is a typical problem with LCD Monitors, they start to experience no image, or on/off screen issues, the problem is the inverter board, try to replace the inverter board. This should work.
Thankyou, :) V
Jun 24, 2009 | Televison & Video
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Toshiba Satellite A100-S8111TD Notebook Logo
507 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
