Question about Car Audio & Video
Sony EXCD-3RF 10 CD changer
I have a Sony EXCD-3RF 10 CD changer in my car. It worked fine until a few days ago. Now, when I turn the Sony head-end unit on and select CD, it loads a CD, hums away for a few seconds, then says "Error" on the head-end unit display, and goes to the next CD, loads it, and repeats the "error" cycle. I took it out, and blew out the insides with compressed air, re-installed, it and it does the same thing. I tried with with a different magazine - no change.
  • Anonymous Dec 26, 2008
    cant move cd from one cd to the next
2 Suggested Answers
gopakumarg43
  • 75581 Answers
SOURCE: I have a Sony EXCD-3RF
Hello
Your CD players' Laser Pickup unit may have damaged; or its strip wire going to the circuitboard had broken carbon tracks in it. Anyway it doesn't pick up signals that pre-burned onto the CD. Sometimes the laser diode inside it have damaged, resulting no Laser Emission. You just take it out from the car and open it carefully, and clean the lens of the laser assembly with some soft material like flannel or with an ear bud. Never use any kind of solvents, since the lens is madeup of very high quality plastic material; hard solvents may damage it. Blowing compressed air only removes any dust, not any fungus. Normally the lens get a type of fungus, that will make it somewhat opeque, and the reduce its reflecting sensitivity. Replace the flat cable fitted from the Laser Unit also. Make sure of its connections while buying a new one. Some of them has special type end connections, and look it keenly when buying it. Same side and opposite side connections are present in different type of CD players.
Now your CD player have the fault, that it doesn't detecting the lead in trak of the recorded CD. It may surely be the fault either to Laser Pickup Unit or the strip wire to which it is connected to the circuit board. Ok.
Posted on Nov 20, 2010
Cdx-705
Most cd changes only work with like brands. Sony with Sony .jvc with jvc. Find a manual for a brand new model on google or the the manufacturer and see if it has a problems section
Dec 27, 2013 | Sony Cdx-705 10-disc Intensified Shock...
I need a wiring diagram for sony excd 21
Sony head units normally have a 9 pin or a 16 pin connector. Both are listed below respectfully.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
Here is a link to your Sony EXCD 21 instruction manual.
http://www.docs.sony.com/release/EXCD21.PDF
Nov 07, 2009 | Sony EXCD-21 CD Changer
My car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
Sep 09, 2009 | Sony CDX-454RF 10-Disc CD Changer
1993 Toyota Vienta Ultima, ''Fujitsu Ten'' INF4 fault
i had the same proble. i happened to remove the changer from the boot for a few days and have a look inside but did not see anything wrong and when i put it back in it worked.
i expect it is as simple as disconnecting the changer from the head unit, turn the head unit on and off and then reconnect the changer resets the connection between the two.
Jul 31, 2009 | Car Audio & Video
Hi i have a older cdx-65 cd changer
IT WILL NEED A SERVICE, POSSIBLE THAT ONE OF THE SWITCHES IS FAULTY
oops caps lock was on sorry :)
Mark
www.blueice-electronics.co.uk
Nov 04, 2008 | Sony CDX-656 10-Disc CD Changer
CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
May 13, 2008 | Sony CDX-T69 6-Disc CD Changer
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
