Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore 106.71192101 refrigerator icemaker doesn't produce ice
I have a Kenmore 106.71192101 refrigerator and the icemaker stopped working. The ice maker is hooked up to a RO system. I know water is getting to the Valve Solenoid but the water is not going from the water solenoid to the water tube to the actual ice maker so I replaced the Valve Solenoid. That didn't work. There is still no water coming to the water tube. I have checked all the electrical connections. The shut off arm is sort of flimsy so could the problem be within the icemaker itself so that when that arm is down it not calling for water? Any suggestions would be most appreciated. I have included the link to the icemaker diagram. Thank you.
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00007&componentDescription=ICEMAKER&documentId=P0207008&modelNumber=10671192101&productCategoryId=0166000&brandId=0582&modelName=REFRIGERATOR&backToLink=Return%20to%20Sub%20Components
  • Roger Lee Teutschmann Dec 01, 2008
    That was the problem. I replaced part 35 and everything is working great. I appreciate your help.
  • 120 Answers
Ok follow these steps to trouble shoot 1st remove white cover from front of ice maker there you can now see the module of the unit .that would be part number 35 on the parts list. 2nd get a 12 gauge insulated wire about 2 inches long and stripp the ends of it . insert it in the two holes in front with letter h and t live there for about 20 seconds now look at the forks inside are they moving if yes check fill tube for a plug of ice that wont let water fill the the ice maker if no they dont move repl that part 35 you can repl your self just disconnect unit remove the three bronze philip screws and pull out ahh but first remove wire harness so it will be easy to pull out ok thanks
Posted on Oct 17, 2008
Remove the three screws that hold the icemaker on to the refrigerator and then disconnect the wire harness from the back. Make sure that the refrigerator is unplugged first. Take the front white cover from the front and remove the wire harness from the module. Remove the three screws that hold the module in place and pull it out. With some needle nose pliers squeeze the clip that is on the big plastic sprocket on the front of the module and push it through. Pull the plastic sprocket off the front and you will see black charring in the wheel and also on one or two of the copper prongs underneath. Scrape the soot off of the contacts with a razor knife. Next the prongs that have burned the ends off, bend them up to the same level as the other prongs and put the little bend on the end with your needle nose pliers. Check to make sure that all of the prongs are about the same height. Assemble it together in reverse order and plug the refrigerator in. Now take the 12 gauge wire and strip the ends and connect them to the h and t holes. If the forks go around and water fills the ice tray you have fixed the problem. This is the solution for those who can't afford the hundred dollars to get a new part.
Posted on Oct 08, 2011
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Samsung refrigerator ice maker
    Many icemakers use a bar or a sensor to shut off water when ice levels are at a maximum. Check to see if it's bent, missing, or pushed down below the ice level, tricking it into thinking there's no ice there.
    Aug 03, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Kenmore icemaker model 795.7102 not producing ice
    is the metal arm in the lowered position or raised?.. needs to be down..
    Feb 02, 2014 | Kenmore Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    Icemaker doesn't work
    Icemaker seems to be working now.
    I think that moving lever and switching on/of helped. I see and hear that it is producing ice now.
    Jan 10, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
    Ice maker won't stop producing ice, even when bucket is full.
    the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
    Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
    Replaced icemaker with new one but still not working
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
    Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
    Kenmore Side By Side Refrigrator ICe Make Not working
    Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
    Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    1,235 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    acrman404a
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
