Question about Sabrent Computers & Internet
Sabrent 5 in 1 adapter usb-dsc5
Attempting to save files to remote storage from HD in Gateway computer before reformatting HD after motherboard replacement
using new dell laptop w/ Vista
all hooked up
HD on Gateway switched to "Master"
can't "find" Gateway HD on any of the USB ports
thanks
    Genius:
  • 1,605 Answers
Gateway hard drive need to be "slave"
usb need to be inserted before turning on the PC.
Posted on Oct 31, 2008
Sabrent external floppy reader is asking me to format my floppy disk. how can a format it without deleting my files on floppy disk?
Your floppy disk drive may be defective. Also, Some floppy drives are manufactured differently. Your best bet is to find another floppy drive to read your floppy disk. You can try to take it to the nearest computer store and ask them to read it for you. If they can read it at the computer store? The Sabrent drive you received if bad. If they cannot read it the floppy is bad. If the floppy is bad you can try to download free data recovery software to attempt to recover your data, files etc. Good luck
Aug 14, 2014 | Sabrent Computers & Internet
I have a Sandisk Cruzer 8GB pendrive. I was copying files halfway until a message pops out telling me that my drive is not there. i ejected and reinserted the pendrive, but I couldn't delete any files...
Right click my computer and click on manage. In disk management try to reformat as another solution for your usb storage drive. Try another usb port on your computer as well when you reinsert it and restart the computer. Usually when a usb device turns off and doesn't show up like yours did the device could be faulty or the usb port you have it connected to or for laptops sometimes the usb ports turn off if only using battery instead of ac adapter. There are power save modes for usb ports so have to check that in device manager as well. Good luck!
Dec 22, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Sabrent USB 2.0 5-Port PCI problem - ''Pri Master HDD Error''
If you already haven´t installed the driver, I would recommend downloading it from http://www.sabrent.com/drivers/UF6.zip and only then, after a successful install, connect the hardware.
Mar 30, 2010 | Computers & Internet
Mass storage controller driver for gateway mx6421
A 'mass storage device' is any device on which files can be stored (HD, Memory card, thumb-drive etc.) so that controller is not for the USB ports as such, but may indeed be for a storage device that plugs into a USB port (card-reader, external HD). For a laptop, it may be for a built-in card-reader which is connected internally to the USB bus.
Go here and enter your laptop's serial number to be sure of getting the proper drivers specific to your machine, as you may be trying to use the wrong driver. Only by entering the serial number can you be sure of getting the correct files:
http://support.gateway.com/support/d...ter.asp?Tab=My
Aug 03, 2009 | Gateway MX6421 Notebook
Sabrent 5in1 USB-DSC5 doesn't recognize 2.5" WD hard drive
I have had a different problem with this product. But, I have read many postings on its problems. It seems that for certain hard drives the jumper should be set for something other than 'master', either CS or no jumper at all. This seems to be true for only certain HD's.
Hope this helps.
Scott Bolton
Mar 18, 2009 | Sabrent (USB-2535) (USB2535) IDE...
Sabrent 5in1 USB-DSC5 USB2.0 to SATA & IDE cables HDD not in Windows Explorer
There shouldn't be any problem accessing FAT32 drives of that size.
Check your disk management (right-click "my computer", hit "manage" and then click on the "disk management")
It should tell you what kind of formatting the disk is, and what the drive-letter is.
If it shows as being FAT32, then you're fine. If it doesn't, the FAT has been corrupted and may require a disk rescue or some kind of disk fixing utility.
Assuming it shows the partition as healthy and FAT32, but it doesn't have a drive-letter, right-click on it and "change driveletter". Pick a letter and hit OK. It should now show up!
Aug 19, 2008 | Sabrent (USB-2535) (USB2535) IDE...
Sabrent external hard cannot save file on it
Make sure you have not protected the drive and that it is shared for use. Go to my computer, right click on the drive and select sharing .. make sure you have the drive shared and that it DOES NOT show it as READ ONLY in the check boxes at the bottom of the screen.
Jul 19, 2008 | Sabrent 1 Bay USB 2.0 External Drive Case
Internal USB Card Reader
Most add-on USB2.0 cards have the standard USB header on them if you have the room for a PCI card.
Feb 15, 2008 | Sabrent (USB-2535) (USB2535) IDE...
Computer doesn't see hd
hi, re: sabrent enclosure:
sort of same issues. documentation is feeble. hd powers up. red light is on.
but the new pc doesn't recognize the drive and, obvously doesn't assign a
drive letter to it.
i tried reversing the cable, changing the hard drive, using different usb port,
re-booting. still doesn't see the drive.
1. jumper settings are correct
2 i use vista, not win 2000 or xp
2 harddrive is old, from old computer
vista doesn't have 'my computer'
i can find manage disk management
can't right click becausse the drive isn't there
how do i change the hdd settings from dynamic to basic if i can't see the drive?
answers to your questions":
1. i'm running windows vista home
2 size of drive... it's old and probably fat(32) under 1g
3 i cycled through the settings
j8 jumper settings
slave, master, & single
no settings work
4. yes i heard the drive spin up
5 the led is red, not green
thx again for your efforts
ken bossewitch
kb@bossewitch.net
Dec 03, 2007 | Sabrent (USB-2535) (USB2535) IDE...
How to connect a IDE-to-USB cable to a 2.5 inch drive?
1) You will do no harm by reversing the connector, but the PC won't "see" the drive at that point (if your drive has an activity LED it will be permanently ON if the cable is reversed) 2) Most times the USB will have enough power to drive the HD all by itself, but if you are going through a hub that may not be the case. In that situation, plug the device directly into a USB port on the PC.
Apr 22, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Computers & Internet Logo
794 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
