ISATAP adaptor In the device manager ISATAP driver is shown with yello exclamation mark waht should i do? can i uninstall it and reinstall? I have toshiba satellite A-135-S4677
  • 5 more comments
  • Anonymous Oct 21, 2008
    i have this issue too
  • dtru Oct 21, 2008
    i have the same problem
  • jczadiaz Nov 17, 2008
    I have the same problem, I have a Hp Pavilion tx1000, and I was eorking with an ineternet wireless connection, but as fast as one day to another, the Isatap Adapter is not working and I can´t have any connection
  • kevingee Dec 12, 2008
    I also have this same problem on my Toshiba Satellite.
  • linajay90 Dec 26, 2008
    at dat isatap adapter i hav a yellow mark!!!!!!!!!!1 its seems is not functioning
  • montie 3 Feb 21, 2009
    there is a yellow mark on my isatap adaptor what can i do to solve this problem?
  • mgobrail Mar 06, 2009
    HP-pavilion ze4900
    Vista Ultimate
    without me installing any software or hardware, the system installed the driver by itself, but failed & gave me that yellow exclamation mark in front of the ISATAP ADAPTER # 4. When I right-click to update the driver, the search reveals that I have the most updated software. What is wrong? I don't know!!!
  • 40 Answers
You have ipv6 enabled, this is to help the worldwide convergence to ipv6 form ipv4 . were running out of addresses if not already have ran out.
so from what i can tell it works with the tunneling adapter. altho it is still doing stuff on your computer, it's needed to make the internet work right now, if anyone of you have a "microsoft wi-fi miniport adapter" all of a sudden and you also don't like that you can't get rid of it unless you go to the web and download the old driver.
neither the miniport or the isatap adapter are actually "needed" you can get by without isatap if you either disable or uninstall ipv6. virtual wifi isn't needed, but it's uber cool cause it's for your wireless card and if you connect wireless to the internet, it will let you wirelessly share out that connection wirelessly , (like your a wireless router)
i think i should not that "eventually" you will need to install ipv6 to browse the internet.
more importantly it actually isn't designed to be a "TAP" but it certainly could be the target of hackers in the future including the mini-port (only because they are both new)
http://www.istartedsomething.com/20090516/windows-7-native-virtual-wifi-technology-microsoft-research/
http://en.wikipedia.org/wiki/ISATAP
Posted on Jan 21, 2011
How do i fix setup.exe has stopped working
I ran into a similar problem with an"uninstall" in the past. It seemed that the function removed some critical part of my laptop program. I was at a loss and someone suggested that I use the "restore to an earlier time" feature on my laptop. It worked for me. Go to START and search for RESTORE......... Just put in the date prior to installing the software for your Brother printer. Hope this helps.
Dec 13, 2014 | Toshiba Satellite Computers & Internet
Isatap adater 11 driver
Get the detail of the problematic driver in the Device Manager (and post it here please):
[Start] Control Panel, System, Device Manager, [Component Name], [Component with Exclamation], [Right click], Properties, Details tab, Property pull down; chose Hardware Ids and write down the VEN and the DEV sections in the Value's box (including the VEN and the DEV words)
Please do not download drivers from questionable websites because it may contain malware.
Feb 04, 2014 | Computers & Internet
Need new download of ISATAP drivers
Greetings,
On a Windows Vista-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark (!) next to it in Device Manager.
You can safely ignore this error message. This error message does not indicate a problem with the adapter. The adapter will continue to work correctly.
Check out this article for more information on this:
http://support.microsoft.com/kb/932520
If this is still not working,
First try to reset Winsock from command prompt, this will reset all the Network components to default:
Click on start, type CMD,'Right click and Run as Administrator'.
At the command prompt type:
netsh winsock reset catalog
In such a case, I suspect this problem to be caused by network adapter missing or corrupt. Please firstly reinstall the driver for your wireless network adapter. Then try to reinstall Microsoft ISATAP using following steps:
1.In Device Manger, right-click the item of Microsoft ISATAP and select Uninstall.
2.Still in Device Manager, click Action and select Add legacy hardware.
3.Click Next, and select Install the hardware that I manually select from a list (Advanced), click Next.
4.Select Network Adapters and click Next.
5.Select Microsoft in left panel and Microsoft ISATAP Adapter in the right panel.
6.Click Next and finish the remaining wizard.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution, your response will be appreciated.
Thank you and Kind Regards
Gowtam R
FIXYA Solutions Engineer.
Mar 18, 2013 | Microsoft ISATAP Adapter
ISATAP Code 31?
receive error code 31 if the device driver is not updated.
As you have already updated the device try reinstalling the device driver and check if that works, if that does not resolve the issue you may ignore the error message, below link will you go more information related to this issue:
On a Windows Vista-based computer or on a Windows Server 2008-based computer, the Microsoft ISATAP adapter appears with a yellow exclamation mark next to it in Device Manager, and you also receive an error message
http://support.microsoft.com/default.aspx/kb/932520
Steps to uninstall and reinstall the device driver:
Uninstall and reinstall the device from device manger. Steps to uninstall the device:
i. Click Start, type devmgmt.msc and press enter.
ii. Locate Microsoft ISATAP Adapter device
iii. Right click on the device and select uninstall
iv. Restart the computer for the changes to happen
Uninstall and reinstall the adapter from Program and features. Steps to follow
i. Click Start and choose Control Panel
ii. In Control Panel double click on the "Programs and Features" icon.
iii. Here you can find all the programs and items which are installed in Windows Vista.
iv. To remove adapter click once on the program and then click on Uninstall/Change and follow the prompts.
hope this helps
Jul 03, 2012 | Microsoft ISATAP Adapter
Hello, I have Vista home premium on a Compaq laptop, windows. I have the Device Manager open and the isatap (with a lot of numbers in perenthesis after it). The yellow exclamation point is on it. how do...
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
cd/dvddrive not seen could be a registry problem
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware
Oct 31, 2011 | HP Compaq Presario F500 F700 and G6000...
My asus device drw2014l1 ata device is not being red. the hardware is working according to the properties but the asus device has a description saying this device cannot start and on the manager device it...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question or exclamation mark ? ! or red X right click you will have options to update driver,roll back driver,, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device:
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 30, 2011 | ASUS DRW-2014L1 DVD-RAM Burner
Recently,i formatted my notebook but before that my notebook can't detect any wireless connection and when i go to the device and printer my pc have an exclamation point and when i troubleshoot it... the...
Greetings,
You need to download and reinstall the device drivers and system software from your notebook manufacturer's website or reinstall from your system CD. The exclamation point means just that, the device is unable to start because the required DLLs and supporting software are missing.
Apr 19, 2011 | Microsoft Computers & Internet
EXCLAMATION MARK IN THE DEVICE MANAGER
Regarding the Microsoft ISATAP Adapter error, you can ignore it safely. Please refer to the following link:
http://support.microsoft.com/kb/932520/en-us
Dec 07, 2008 | HP Pavilion dv6000z Notebook
There is a exclamation mark in the device manager beside the microsoft ISATAP adapter#5. Should this exclamation mark be here?
No. If you have the driver for it try reinstalling it. If you don't I would delete the device and reboot. This will force the drivers to be reloaded unless they were deleted...If they were deleted and you are not very good in computers, you may need a bit more troubleshooting than on line help.
Dec 07, 2008 | Computers & Internet
Isatap
Ivon
ISATAP is a virtual device for transfering packets.
Somehow this must have gotten corrupted, Try uninstalling your network card. Once thats done scroll up to the top of device manager and right click on Computer and choose "scan for changes"
this should reinstall your network card and with it your ISATAP protocols. This should fix your problem. I've had to do this acouple of times myself (Quite common in Vista)
Hope this helps ya
Dave
Nov 06, 2008 | Computers & Internet
Computers & Internet Logo
1,158 people viewed this question
David Payne
David Payne
