Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Superba 48 Refrig
Compressor never seems to shut off
  • 943 Answers
Hi, is the fridge cold enough.pull fridge from wall, remove back panel. clean all coils. this should solve the problem. thanks the appliance doc
Posted on Oct 05, 2008
The Refrig quit cooling. There is power as the light still powers on, but the compressor will not run???? any thoughts?
replace the ptc overload on the compressor as this has burned out,it powers the compressor and easily unplugs and plugs in with a replacement its mounted on the side of the compressor body
Dec 22, 2010 | KitchenAid Superba Architect KBCA06XPBS...
Condensor fan running all day
when you say you removed the cardboard, did you remove the back panel that covers the compressor, fan, and coils from the back? If so that is what is causing it to run too much, this will also effect the cooling.
May 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
The condensor of the refrig. will click on when I move the temp control and then it will shut down a few minutes later. What could this be? When the the condensor is running the refrig is nice and cold, I...
I believe you're talking about the compressor and it sound like the starter/overload relay is cutting it off because either the relay is bad or the compressor is going bad. Test relay here.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
10 year old refrig cools only if freezer temperature is on maxium
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 18, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
KA KSRS series lost cooling in refrig only
Check for frost accumulation in freezer or no freezer fan
Jan 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Not cooling and the partition of 2 doors are very hot
check for a clogged condensor under the refrig, as well as the fan behind the refrig need to be cooling off the compressor. on e or the other perahps both is the reason for the HEAT between the doors
Jan 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
May 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba
To the person who hears a clicking sound you are correct, the compressor is trying to start but is not starting and that causes the overload to trip (click) wait a short time and it all happens again. Either the start relay is bad or the compressor is locked up. Less than 1 year old should be in warranty. If you want to try to check the relay you will need to unplug it from the side of the compressor. Once removed try to shake it and if you hear a rattle noise the relay is bad. To test the compressor you would need a test tool or be very experienced to perform accurate test.
supertechks
Nov 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,358 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
rugby prop
Lawrence Oravetz
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
