Question about Garden
Slow starting Lawn Tractor Engine
I have a Briggs & Stratton engine that now has very slow starting torque. The battery is good but the engine will not start due to too low cranking
revolutions. Is the sarter bad or is the engine exhibiting too much internal
friction. The engine is a 10 years old model 278,707
-- Mark
  • 48 Answers
After 10 yrs you would have less friction and less compression - did you have your battery load tested ? if you did and it checks ok then it could be a starter prob . try using jumper cables from your auto . neg to ground then pos directly to starter . if it still winds over slow its the starter
Posted on Oct 17, 2008
I have a petrol golf cart wont start
Brian, If engine is of overhead valve type and engine turns over with plug out and will not crank when plug in or turns very slow, the problem is probable valve adjustment required or decompression release faulty on cam shaft. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kohlerengines.com/maintenance/basicTroubleshooting.htm
briggs and stratton ohv hard start crank fix
How the compression release mechanism works on Briggs and Stratton OHV...
HOW TO ADJUST VALVES FIX HARD TO START Lawn Tractor with OHV Briggs Engine...
Aug 16, 2016 | Cars & Trucks
Bownes lawn tractor wont turn over. Battery fully charged and all safety switches were changed. its a briggs and stratton 12 1/2 horsepower
with a volt meter set to DC, pull the wires off of the starter solenoid coil (the small wires) and check for 8 - 12 volts DC at the wires when the key is turned. A poor connection at the solenoid coil will cause slow turning engine cranking or none at all.
If you have 8 - 12 volts there check for voltage to ground on the large cable that goes from the solenoid to the starter motor, one probe on the cable and the other on ground or ( - ) at the battery. Turn the key to start, if you have voltage to the starter motor but it does not turn loosen and retighten the mounting bolts to the starter motor and if that does not help do the same for the engine to ensure you have a good ground. If none of that works your starter motor needs to be replaced, if you have no voltage to the motor the solenoid or battery connections are faulty.
You can also quickly test starter health by conecting a set of jumper cables to a good battery, clamp the neg. to the engine block anywhere and tap the pos. to the starter cable connection from the starter solenoid, if the engine spins over your starter is healthy and the issue is certainly between the key switch and the starter solenoid.
Jul 07, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Briggs statton 375 starts runs very high revs how can i slow it down
remove the top cover from the engine and see if theres a nest stopping the governor from moving
Aug 20, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
What are the required cranking amps for a briggs and stratton 18hp
if starter turning over slow probably needs taken apart and cleaded or battery not charged enough
Apr 02, 2012 | Briggs & Stratton Garden
Tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Mar 25, 2010 | Briggs & Stratton Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
292 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
