Question about Whirlpool LER4634J Electric Dryer
Dyer problem dryer gets very hot and does not shut off
  • Anonymous Nov 29, 2008
    my dyer don't get hot
    Sergeant:
    Champion:
  • 324 Answers
Check to see if your heater is shorted .
Posted on Nov 11, 2008
What does error code E65 mean on dryer.. does not dry clothes well
Hello Becky;
My name is Peter. I am a retired field service appliance technician.
E65 = High limit thermostat trip count too high.
In other words, you probably have a restricted air flow problem. Your blower will shut down if your plugged up with lint.
In the back of your dryer is a hot air distribution manifold. At the bottom of the manifold is a small round connection. This is generally where the dyer air flow is blocked. There are only a few screws holding it on. Un plug your unit, remove the hot air distribution manifold, Clean the manifold and around the blower wheel. Turn the wheel by hand to ensure it is not stuck and free.
If this is not the problem, get back to me and we will talk about the high temperature thermostat.
Jan 01, 2015 | Frigidaire FASE7021NW Laundry : Dryers
My dyer gets hot then it gets e64 then my dyer stops
It could be clogged vent or faulty sensor or thermostat control board Best way is check for clogged vent or any rust or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Kenmore Dryers
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Stackable dyer gets too hot in the back and i cannot find a filter
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 05, 2011 | Samsung DV316LGW Dryer
The dyer is working, but the dyer is not blowning any hot air
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Kenmore 600 7962 Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
Dyer cutting off
sounds like a bad motor, motor is overheating and shutting down
Nov 07, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
