Question about Harman Kardon AVR 235 Receiver
My AVR 235 stays on stand by
My AVR 235 doesn't turn on, only stay on stand by. I shut down everything for 30 minutes and nothing, than I checked all speakers connections, same results.
  • dfaudi Nov 08, 2008
    Same problem. Stays only in standby mode.
  • johnonbeach Dec 28, 2008
    Same problem, goes in standby and won't start. Was able to reset it a couple of times, but now it won't even reset. Checked speakers and ok so quite annoying....
    Habit-Forming:
    New Friend:
  • 91 Answers
Hello
problems with Avr units are the internal supply always fail with in time.
mostly -15v and +15v are the regulators 7815 and 7915.
the mpu takes care of the AVR .. the control unit stops the AVR not to get more damage ,
if you now or have the knowledge about Electronics, check power supply voltages, regulators, check capacitors.
dont forget to check soldering points also.
Good luck
Happy to help
Posted on Aug 02, 2016
    Genius:
  • 1,175 Answers
Hi...
That sounds like a amplifier module /section that has failed.
Do you ever get power surges at your place?
Posted on Jan 19, 2009
Wont turn on it stays on stand by
This could be a power supply issue to a audio output problem, I strongly recommend a top notch tech to check your unit because this is a high end device.
Dec 30, 2010 | Harman Kardon AVR 235 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Denon avr-1706 receiver just shuts off
This sounds like the amps protector circuit has been activated due to thermal overload. switch it off for an hour or more to let it cool down, make sure your spkrs are connected properly, don't parallel. Try using a fan on the unit to get that heat away. Get a techie friend to give the insides a once over, and clear away any dust that has built up.
hope this is of some help,
Cheers Kimbo.
Sep 12, 2009 | Denon AVR-1706 Receiver
Denon AVR-1604 too large front speakers blew the avr
Try disconnecting the speakers at the receiver. turn it on radio or any other source and turn up the volume. If the receiver still shuts of, there is an internal capacitor issue and needs serviced. More than likely though, it's a speaker problem. If the speakers were underpowered and at max volume, chances are the damage was to a voice coil in one of the speakers. If the receiver continues to stay on without being connected it's ok. check your speaker wires as well. Frequently loose braids on wires touch each other and create very little resistance until turned up, more volume, more resistance. Then the receiver puts itself into protection mode so no damage will occur. If you need further help, post a comment and I can help you troubleshoot further.
Aug 17, 2009 | Denon AVR-1604 Receiver
Reciever Powers Down
Hi...
Check ALL your speaker connections at both ends.
What kind of volume are you running it at and what kind of airflow do you have around it>?
Thanks
Aug 25, 2008 | Harman Kardon AVR 235 Receiver
Wont stay on.
The only way you can fix this is you have the proper tools and have very good soldering skills. If so, I will post more instructions on how to fix this.
It has a blown channel, it can not be fixed without some good troubleshooting skills. The protect mode is so you don't cause more damage to it. If you continue to turn it on, you may cause more damage.
Your best bet is to take it in to get repaired at a service center.
Let me know if you require more help,
Dave
Jul 01, 2008 | Harman Kardon AVR 235 Receiver
No sound
I had the same problem, unplugged the receiver for 5 minutes, then when I plugged it back in, it worked.
Jan 05, 2008 | Harman Multimedia AVR 235 7.1 Channels...
Receiver shuts down and will not turn back on untill you unplug and plug back in
Nope. sorry to burst your bubble but your problem is pretty common on this unit. Its bad capacitors in the power supply and probably not worth repairing in a repair shop. since this is a solid state reciver, there are no user replaceable parts inside.
Sep 24, 2006 | Harman Kardon AVR 235 Receiver
Harman Kardon AVR 235 Receiver Logo
506 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
