Question about Cadet Manufacturing 67508 Coil / Ribbon Compact Heater
No heat The fan on this unit runs, but there is no heat. I have power to both leads. Can you help
  • Anonymous Dec 17, 2008
    I have the same issue, seems like the coils are out.
The element above the fan has brobably gone bad. you can take the grill off of the wall and inspect the coils for breaks with a flashlight. if you do see a break in the coils then the heater is toast.
Posted on Aug 17, 2009
Scenic e620 power up problems
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Hope this helps.
Nov 23, 2012 | Computers & Internet
Gateway gts5674
Desktop or Laptop computer ?
The high speed fan could be a dirty computer or thermel paste has dried causing you computer overheat.
Hope this helps.
Nov 21, 2012 | Gateway (4000068) Motherboard
I have a mcp6pb m2+ mother bord will boot up nextime it will not
If this is a desktop computer this could a problem with the PSU it might not be sending enough amps to your computer for it to boot up and enought to run the fan
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
hope this helps
Sep 21, 2012 | Biostar MCP6PB M2+ Motherboard
My computer suddenly shut down & not power on
hope this helps
Aug 09, 2012 | Intel Computers & Internet
Dell Dimension 9200 amber ligth on the power button
hope this helps
Aug 01, 2012 | Dell Dimension 9200 PC Desktop
My Dell Inspiron 1546 Laptop will not turn on. When the power button is pressed, the front white light comes on for ten seconds, then it switches off. Same reaction on battery or AC. When AC is plugge
hope this helps
Jul 15, 2012 | Intel Dell Inspiron 1545/1546 Laptop--oem...
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Computer was running . but the processor area was very dusty so i open the processor fan and clean then i locked the fan and when i on the computer then fan some moves then stop.what i do
how did you lock the fan ?
you might need to replace the fan
check the power lead/s to the fan
this could be a problem with your power supply unit and electrical leads
if the PSU units fan is not working the psu is fauty
check all leads that attach from motherboard to you hard drive
check that your dc/dvd drives are working
make sure the electrical leads and connections are secure
and clean all dust from electrical connections
hope this helps
Oct 12, 2011 | Intel D945GCNL Motherboard
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
Cadet Manufacturing 67508 Coil / Ribbon Compact Heater Logo
122 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
