Question about Hitachi 51SWX20B 51" Rear Projection Television
3d and green line looping down
I dont know what to do but i value this tv still . its aprox 5 years old sound is good still .when i use a wooden probe and pushed on the heat srinks second in from the rear one the right from the rear the green looping line coming down from the top did start to wabbel a little / also during the majic focus the green top center block is veary low and it seams to hold operation for a while then a number 5 appears on the screen
  • 1 more comment
  • john berlinghof Oct 05, 2008
    my trade is in refrigeration service 25years im cofident enuogh to remove and replace resistors although im not shure as to where to watch for high voltage shock. i have worked on a few crt units and so fare no shocks. i downloaded the manuals .thanks for the url.
    i was hoping you mite give me an idia as to where to start looking for the problem area.eg witch board of the threee left center right. ? when the problem occured originaly the tv was on and there was a small pop sound . instantly the problem showed and hasnt changed at all since
  • john berlinghof Oct 08, 2008
    still looking for more help other then just a service manual. any sugjestion where to start the repair for this fault
  • 10,594 Answers
Do you have your Hitachi 51WX20B service manual and let me know about electronics knowledge and repair know-how about tv to guide you further.
If you dont have service manual, download it form Here for free. get all parts of file and use WinRAR to extract file.
Posted on Oct 05, 2008
  • Shahid Electronics
    Shahid Electronics Oct 05, 2008
    I hope with help of service manual you can fix it as you have tech experience.
    How about rate this solution?
    Good Luck
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
New 60ph6700 hd 3d tv /watchind hd sports fuzzy grass and background/once in awhile lines run through screen/its only two wks old??
Anything new has a chance of failure the first month or so from cold solder joints on circuit boards. If it passes the first month it may last 8 or 12 years. Send it back under warranty.
Nov 29, 2013 | LG 60" 6700 Series Plasma HDTV - 60PH6700
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Picture is unstable (jittery) colors (especially red & green) are smeared. Picture seems to have aprox. 4 horizontal not in line boxes.
Ur tv have a problems known as a convergence problems it dead.Tv have colors lines like R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Tv have a dead convergence board,board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv picture convergence problems.The shop,will coat u like $300-350 for parts and labors.
Jan 31, 2011 | Hitachi 61SWX10B 61" Rear Projection...
On the right side of the tv aprox.3-4 inches wide down verical its black. It`s like the screen shifted left??
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 23, 2011 | Hitachi 60SDX88B 60" Rear Projection...
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
Pink lines only down the middle of the screen aprox. 12" wide for spit second.
Most likely will get worse as you are describing a failing control bd. The part # is 6871QCH038A and is a fairly complicated repair. A good deal of disassembly required, and I would take advantage of your service agreement.
Apr 13, 2008 | LG 50PX1D 50 in. Plasma Television
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Sharp 28JW73H Green tint with lines across screen
Note: unmatched Make / model info........please clarify...T.
Nov 16, 2007 | Panasonic PT-52LCX66 Projection Television
Hitachi 51SWX20B 51" Rear Projection Television Logo
81 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
