Question about Haier 42EP24S 42 in. EDTV-Ready Plasma Television
Haier tv After a power outage my tv is dead. When I plug it in nothing happens. Is this something I can fix or do I need to take it to a shop?
  • aubrey00000 Feb 28, 2009
    my 42 in. is not turning on and i tried the remote same not working and what should i do?
  • 61 Answers
If this unit is under warranty you can take to the shop
Posted on Oct 09, 2008
After a power outage my Panasonic smart tv came on for 2 seconds but after that it turned off and it wont come on after 24hrs
The power outage probably popped an inside fuse or damaged some electronic components. If you are capable, unplug the tv and place it face down on a soft towel. Unscrew all the screws on the rear that hold the two halves together. Lift the back panel slowly making sure all is free. Look for the fuses and check if they are blown. If they are, replace them with the same rated fuses. This is the cheapest fix. If the fuses pop again after this, then something beyond the fuse was damaged. You will need a repair shop to troubleshoot it. Once fixed, plug the tv into a surge protector for future use. Hope this helps.
Apr 09, 2016 | Panasonic Televison & Video
My haier htr20 tv wont power is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
Model # HL32D1 Haier LCD TV Wont power on i tried puling plug and plugging back in This happened like 2 weeks ago but came back on now its doing same thing"
Tv have problems with it power supply board,that the board where the power a/c cord plug into it.Tries websites like, to buy a whole new refurbish power supply board for the replacement.Or u have all the tools also can do basic soldering and u know basic electronic too?Yes,check the whole power supply board carefully for dying and dead capacitors parts.These capacitors parts alway bulges up or puffing up onto it tops.Replaced all these dead bad capacitors components parts,should get the tv power back to the tv unit again for good.
May 24, 2011 | Haier HL32D1 32 in. TV
Had a power outage and now my tv is totally dead. Any suggestions?
It died from the power surge. If it is still under warranty, check if it covers power surges. If not, you should probably buy a new TV. Buy a good quality surge protector just in case something like this happens again. It's a good idea to get surge protectors for your other expensive electronics too.
Mar 06, 2011 | Panasonic Televison & Video
Had a power outage and now my toshiba 14AF43 tv won't turn on
First, make sure the outlet where the TV's plugged in is working. Unfortunately, a set that's dead after a power failure (especially if it was storm-related) isn't something easy to diagnose without looking at it in person. It might be something as simple as a blown fuse. But the damage is frequently more extensive. Without electronic servicing skills, the proper test equipment and a circuit diagram of the set, there's nothing you'll be able to do to repair this on your own. If you want to keep this set, the best thing you can do is find a servicer in your area who can check it over and make an estimate for the repair. For a small TV, you may find it more economical just to replace it.
Sep 30, 2010 | Toshiba 14AF43 14" TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Television won't turn on. The standby light is out and the tv is just dead
Check the outlet. If you plug a lamp into the same outlet and it doesn't work, you have no power there (reset the circuit breaker or call an electrician).
If the lamp does work, look for a circuit breaker on the back of the TV - it's usually a red or brown rod (about half as thick as a pencil and less than an inch long) sticking out. Press it in. If that fixes it, fine. If it keeps happening, take it to a repair shop - something is wrong inside an, since it's plugged into the wall (lots of electricity available), it could cause a fire.
If there's power to the outlet and no circuit breaker (or pushing it in doesn't help) you'll need a repair shop. (With the current repair prices and the current prices for TV sets, it may be cheaper to buy a new one. Shop around.)
Aug 19, 2008 | Televison & Video
50 inch dlp wont restart after power outage
did you replace the light bulb from the back of the tv set ?
check if its blown ?
if so just replace and your good to go ....
Aug 07, 2008 | Toshiba 50HM66 52" Television
TV making chirping sound
If one of the secondary supplies is shorted, the power supply will "chirp" when plugged in. This is the power supply's way of protecting itself and this usually happens when the horizontal output transistor is shorted. If this set was in my shop and needed a new output transistor, a fair price would be right around $100.
Jun 28, 2007 | Toshiba 32DF46 32" TV
Haier 42EP24S 42 in. EDTV-Ready Plasma Television Logo
111 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
