Question about Samsung 7.3 Cu. Ft. Super Capacity Electric Dryer
Dryer will not move but power good
I have a samsung dv316les/xaa and the power comes on but the drum will not trun any ideas.
  • 4 Answers
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Posted on Dec 17, 2008
    New Friend:
The belt has a sensor. if the belt is broken the motor wont turn. had the same problem and wen i opened the back plate of the washer the belt was siting on the bottom. after looking at it saw there was a sesore thet runs of the belt tention . motor wont run if belt is not there or if its way to loose. hope your problem was as simple as my to fix.
Posted on Jan 16, 2013
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
How do I replace the drum assembly on Samsung DV218AEW//XAA dryer
You may not have a bad drum as that is the least likely item to go bad. What will go bad are drum support axles, support rollers, and bearings that when they go bad will cause the drum to sag and the belt will go loose and may fall off. Please use this link to help you figure which one it is and order the correct part for your dryer; http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/10---/Dryer-makes-noise?r=%2fShop-For-Parts%2fa8b160c26%2fSamsung-Dryer-Drum-Tub-Parts
Good Luck!
Rich Lilja
Oct 01, 2014 | Samsung DV218AEW Electric Dryer
I have a Samsung DV331AEW/XAA dryer that will not run. i have 240V L-L at the plug. the LCD works as normal, meaning it thinks it is drying clothes. the child lock is not on. the dryer is empty. it...
2 things possible here the belt broke or the thermostat by the thermister opened both scenarios will cause your problem if its the 2nd problem, clean the vent and the drier. inside and out
Sep 03, 2013 | Samsung DV331AEW Dryer
Samsung#DV448AGW/XAA check filter light on
Hello. #1-Use a vacuum cleaner with hose attached and vac the drum vent screen inside the drum. #2-disconnect AC power(unplug or switch off 220volt breaker) carefully remove hose from air duck of dryer and vac inside of dryer. Vac the hose and exhaust port. Reattach hose, reconnect AC power and test operation. #3-Problem still present the exhaust sensor or the (most likely) the exhaust fan not working properly. Good Luck!
Feb 28, 2012 | Samsung DV448AGE Gas Dryer
Our dryer (Samsung Model DV218AGW/XAA) has power, no error messages, but will not start. When you press the "start" button, there is a click, but the drum will not move, no heat, etc...
I had the same issue with a Samsung DV209AEW/XAA.
What I found was the belt had come off and the spring on the drum belt pully had come off.
After I disassembled the whole top and front to figure out I could not access what I needed from there I discovered I needed to enter in from the vent is.
Anyway here is some info:
Rear Access:
1) On the back where the Vent comes out you have 4 total screws. 3 of them are on the outside edge and the fourth is more of a middle mount that holds the tube to this bracket. Remove all four screws now you can lift and lean this plate to remove it.
2) This will also free up the vent tube and it can be pulled and cleaned also if you desire.
3) With these items out of the way you can now access the pulley for the belt and other items.
Nov 13, 2010 | Samsung DV448AEE Electric Dryer
I have a new Samsung electric dryer (DV218AEB/XAA)
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067142-/Samsung-Dryer-not-heating-DV218AEB
Click the link for no drum turning. There is a belt in the machine that wraps all the way around it, the belt has come off or broken.
Oct 08, 2017 | Samsung DV218AEW Electric Dryer
Samsung 7.3 Cu. Ft. Super Capacity Electric Dryer Logo
886 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
