Question about Microwave Ovens
Small tear on plastic lining covering the inside of the door
Goldstar Microwave has a small tear on the plastic lining covering the inside of the door, is it ok to keep using the microwave----if not can the cover on the inside of the door be replaced?
  • Microwave Ovens Master
  • 8,934 Answers
That clear cover (sometimes called the inner door screen) is very important.
It protects the metal mesh / screen from debris and corrosion. The metal screen allows you to see "what's cooking" (*grin*) but prevents microwaves from leaking out of the door due to the precise size of the openings in the mesh.
If the mesh rusts or gets grease or food on it, it can arc, and this can damage the screen, then microwaves can leak, causing a burn or fire hazard. (No "radiation" threat, though)
If no arcing or other damage has occurred yet, you can clean the area squeaky with alcohol, then dry it completely and use the smallest possible amount of clear Scotch tape or packing tape to cover the tear and make sure it's flat.
If this fix doesn't work, or it's too big an area, you will have to replace the sheet, which can be ordered.
You'd have to heat it up with a hair dryer, peel it off slowly, then clean the area with something like acetone, then peel and stick the new one.
If you need to or prefer to order it, I would need your brand and model number to help you further.
Posted on Oct 07, 2008
I have a Goldstar range microwave with two small holes in the clear plastic on the inner side of the door. The mesh appears intact. Can this be repaired?
yes you can buy it the material from the supplier for the microwave parts. special paint for microwaves.God bless you
Apr 02, 2013 | Goldstar Microwave Ovens
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
Sharp r520kst door won't stay shut
Aug 20, 2012 | Sharp Microwave Ovens
Door glass is lose and seal is leaking..moisture is forming on inside of glass
That is normally caused by the clear plastic adhesive cover either having been removed or missing. It covers the perforated door inner and stops condensation and food particles from getting inside the door cavity where is cannot be cleaned.
Feb 14, 2011 | Goldstar MV-1526 Microwave Oven
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
Dec 06, 2010 | Neff H5430 Convection Microwave Oven
Everything seems to be working but will not cook
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Goldstar MV-1515 Microwave Oven
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
How do I replace the door handle on microwave?
Once you follow the youtube instructions to remove the inside cover you are ready for the next step.
Remove the six small screws that are adjacent to the window. After this the front plastic is held in only by plastic clips to the metal door. The plastic clips and the screws together hold this together.
Remove the entire door by lifting up and move it to a flat service. If the top vent cover prevents this just remove the two screws on top of the microwave and pull the vent cover off.
With the door lying flat you can pull the plastic frame out on top and bottom and see how the clips work. Now just work you way around the frame until it separates.
Install handle and reassemble in reverse order.
Sep 03, 2008 | GE Advantium 120 Convection/Microwave Oven
Plastic filter cover
There are 2 screws on the top of the unit. Once these are removed the cover comes right off.
Jun 08, 2008 | Goldstar MV-1515 Microwave Oven
Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
382 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
